Question about HP PhotoSmart P1000 InkJet Printer
I have not used this printer for some time and have just installed it on a different computer. I have changed the ink cartridges - but it only prints pink from the colour cartridge - could this be because the cartridge is old? Or could this be another problem?
  • HP Master
  • 8,404 Answers
Is this printer compatable with your present OS? Check at the Microsoft Hardware Colmpatability site ... then ... if it is ... get the latest driver and run your printer again .. if it is still pink ... replace the inks.
Thanks for ysing FixYa.com
Posted on Oct 01, 2010
Not printing at all
The old ink got dried up on the contacts. Remove the ink cartridge and using a cue-tip with water clean the contacts where the ink cartridge contacts the other part. This would be a good start. if the ink isnt coming off easily with water try alcohol, its cheap at most dollar stores just watch out for sparks and flames around alcohol and just pour out small amounts and put container away before use.
Jan 21, 2014 | HP OfficeJet K80 All-In-One InkJet Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
Hi, I have just changed the yellow cartridge on my R265 with proper epson ink cartridge and it is saying that it is incompatible. Can you help please?
Hi If you are using compatable inks try taking the ink cartridge out and put it back in again try this three or four times to see if it will accept it if not try a different cartridge you can sometimes get a duff one The earlier models have a different cartridge than the later models epson altered them and changed the chip
Oct 25, 2009 | Epson Stylus R265 InkJet Photo Printer
HP Photo smart c6180 All-in-one wrong cartridge
Hi The 363 cartridges that came with the printer MUST be used before any cartridges you buy in the shop are installed. The cartridges that come in the printer box are called "host cartridges" their ink is different and is required to install the printer for the first time. Once the installation ink is used, you are free to install & use any cartridges you would normally buy in the shops.
If the cartridge that came with the printer is not working, contact HP technical support and they should send you a free replacement.
Cheers.
Oct 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Expson CX8400 All-in-one printer
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Jul 11, 2008 | Epson CX8400 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lexark X7350
If the contacts are different, then you may have bought a damaged cartridge, or just simply the wrong cartridge and this would explain why your printer cannot recognise the cartridge. Make sure you bought the same number Lexmark cartridge as the old one. Return it to the store as a damaged cartridge if it is the exact same cartridge. Lexmark would not change the design of a working cartridge to exclude customers from using a printer.
Sep 07, 2007 | Lexmark X7350 All-In-One InkJet Printer
HP PhotoSmart P1000 InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
