Question about Whirlpool Kitchen Ranges
Electric range model WERP4120 most of the time I can't shut oven down with the touch panel switch. The panel controls seem to be frozen, can't shut off the timer after it indicates END. Have to cut power source to reset everything.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
pull the plug and
try to check all the wire
and then replaced the touch pad
if the same problem!!!
Posted on Nov 18, 2008
  • Whirlpool Master
  • 19,396 Answers
Replace control panel assembly.
If you enter your model number here (Click) you find replacement parts and free diagrams that will help you in replacing the parts.
  • 3,037 Answers
Basically you have to take the oven apart and check all of the wire connections for the control panel. Test them if you can. most likely the board is going bad and needs to be replaced. Let me know if you need help taking it apart, or if you have any questions with anything as I would glad to help you out with anything. If you don't feel comfortable taking the panels off of the range to check out the control panel, then don't but it isn't too bad of a job. If you want to order a new panel, any retailer of whirlpool ranges should be able to help you out with that or whirlpool itself but you may have to wait till Tuesday for this because of Memorial Day.
good luck and let me know how this goes for you
Posted on May 26, 2008
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
  • 868 Answers
Replace the touch pad.
  • Archie Ferrarini
    Archie Ferrarini May 26, 2008
    The touch pad is your solution and working hands on with this my self I believe it will fix the problem.
  • Archie Ferrarini
    Archie Ferrarini May 28, 2008
    It's problem is one of the 2 ,you have to start by replacing the touch pad first IF any touchpad keys work when you touch them,if 1 pad key does not REPLACE THE PAD.other than that you will have to replace the CONTROL ELECTRIC (alias-CLOCK/CONTROL BOARD).
Top burners OK. On convect bake the oven will heat up to set temperature then shut off and cool down. Normal bake function seems to work ok.
PDF]BUILT-IN ELECTRIC CONVECTION OVEN - Whirlpool
https://www.whirlpool.com/.../Use%20and%...
Whirlpool Home AppliancesBUILT-IN ELECTRIC CONVECTION OVEN. Use & Care Guide ..... To Turn TonesOff/On: Touch and hold COOK TIME until a tone sounds and the lower oven ...
Teach me how to use my convection oven - Chowhound
Jan 01, 2016 | Maytag MES5875BAS Slide-In Electric Range...
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
F2 - E0 Oven temp too high
1. Test operation of door lock on self-clean
2. Test relay contact operation
3. High resistance in oven temperature sensor
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Controls on stove are frozen. Clock blinks and two choices just flash on and off..
There are similar problem: Oven control panel frozen with all functions on this panel shut down but oven light on that can't be off.
Jul 01, 2014 | GE Cafe CGS980S Kitchen Range
Oven overheats and shuts down with F1 error
F1 touch pad / ERC test
This simple test will help determine whether the ERC (Electronic Range
Control or Clock) or the touch pad is defective when F1 error code is
present.
Note: Some models incorporate the touch pad in to the ERC
as a single assembly, in which case this test is not necessary. Simply replace
the ERC (Clock).
Warning: If you feel in any way uncomfortable
performing this test or making this repair, please contact a qualified appliance
repair technician.
1. Disconnect power to the range (unplug the range
power cord or turn the power off to the range at the circuit breaker). It is
very important that the power to the range has been disconnected, so please
double check before continuing.
2. Gain access inside the control
panel.
3. Disconnect the touch pad (also called keypad or membrane switch)
ribbon from the ERC.
4. Make sure there are no lose wires, or anything else
that may cause a short when power is turned back on. Assemble the control panel
back the way it was.
5. Turn the power back on.
6. Wait for at least one
hour to see if the F1 code comes back (usually accompanied by a beeping
sound).
7. If F1 comes back, replace the ERC. If it does not, replace the
touch pad.
Dec 25, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
241 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
