Question about Compaq Evo N1020V Notebook
EVO ! wont boot
Tried that
light comes on and fan for 5 sec. doesnt boot!
Any Ideas? Thanks ahead
  • 1 more comment
  • jcpc May 26, 2008
    The ram is 512
    333mz
    fan is right does work.
    When I got this it had the same no boot up issue except Once or twice it would ,,,,,I saw the screen with windows 98 so I updated it with xp pro, before completion it froze --- waited for 3 hr to see if it would finish , still froze so I manually did shut it off, then never came on since then,
    What are the ways to test the motherboard, have expirence in opening and putting it back together a few times
    thanks again charles!
  • jcpc May 28, 2008
    Thanks man yes...
    my man says yes the gel was very dry, what is the correct lingo and where what link to get that gel??
    Thanks a million gazzillion
    holly and her man javier
    thanks again
    lets go from here
  • jcpc May 28, 2008
    Thanks again this site is awesome, will look for the cpu coolant we do live on an island of 1x4 miles no malls but there is 2 possibilities to ask for that gel....
    hope your solution will fixit..
    we will report back once tested,
    thanks a gazzillion
    h+J
    Scholar:
  • 187 Answers
If the RAM is fine, but it's turning itself off after 10 seconds or so, then it's highly likely the motherboard needs replaced. What I would suggest, if you are comfortable doing it however, is to check the fan isn't simply clogged up (this will determine whether it is a problem with the motherboard itself, or simply a problem with the fan overheating, and the motherboard turning off as a fail-safe). Bear in mind, this will require stripping the laptop down, and should only be done if you can put it back together properly.
Posted on May 26, 2008
  • Steven Burn
    Steven Burn May 27, 2008
    Usually when testing motherboards, you would have;
    1. 2 CPU's
    2. 2-4 RAM chips (depending on the board)
    3. 2 PSU's
    4. 2 Hard drives
    5. 2 Graphics cards
    6. Tube of CPU coolant (the Silicon gel that goes between the CPU and the cooler - very important to prevent over heating)
    Having another spare part for the board allows quick and simple checks to determine whether the problem is with the board, or simply a faulty part.
    In your case, the machine turning itself off, is usually caused by a short in the board, or it's simply over heating. Without specialist equipment, it is very difficult to check this.
  • Steven Burn
    Steven Burn May 28, 2008
    You can obtain the silicon gel (CPU coolant) from most PC stores for a couple of quid.
Wont turn on
Phone will still boot without a SIM card usually just comes up and says that you need a SIM card to operate the phone but it will still boot/charge without it. Could be bad battery most HTC phones will not boot without a operational battery. Pull the battery and plug it into a charger if the Charging light goes on for like 3-5 sec. then off most likely battery is faulty if no light at all, could be a bunch of different reasons.
Nov 23, 2013 | HTC Pc36100
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Compaq presario a900 model a931nr wont boot, help!!!?
Sounds like the battery is in trouble (discharged) or the charger is bad. If you have access to a voltmeter, read the voltage across the power cable plug with the pack plugged into the house outlet socket. Does a lamp work when plugged into the same socket? If the pack checks ok, then the battery may not be able to receive charge. Have it checked by a dealer.
Jul 16, 2009 | Computers & Internet
My evo n610c wont do anything
While turning on your laptop keep tapping the F8 key...It will give you Advanced boot options...Select Safe mode frm the menu ... it will go to the safe mode ... then try to do a system restore to the date when it was working fine...Best of luck.
Jun 15, 2009 | Compaq Evo N610C Notebook
Computer wont boot
Try disambling the system. Clean it with a wind blower. Check BIOS battery capacity. Replace if possible. Power on the laptop. Do you hear humming sound from hard disk ? If you hear sssssssshhhhh sound from hard disk; it's OK. Replace RAM with new one. If problem still exists Than change main board. Hope that not happen. Keep informing.
Feb 02, 2009 | Compaq Evo N1020V Notebook
Acer Aspire 5610 that wont boot up
Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
Aug 15, 2008 | Acer Aspire 5610 Notebook
Doesn't boot up
First thing to do is check your RAM. If there is more than one RAM chip, remove one of the chips, and try booting. This will allow you to rule out a RAM issue.
May 25, 2008 | Compaq Evo N1020V Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
139 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
