Question about Home
Have a pull switch with three terminals marked 1 gang 2 gang and com need to wire a light, which colour wire goes where
    Problem Solver:
  • 16 Answers
It sounds like you have a pull chain switch that turns on one and/or multiple lightsor light and fan. The common wire would be a colored wire (probably black or red) and the one and two gang terminals would be your switch connectors. Neither terminal should be connected to a white or green wire..
I hope this helps out.
Posted on Oct 08, 2010
I replaced a foyer light that is illuminated by a double light switch (switch 1 turns on the foyer light, switch 2 turns on the outdoor porch/garage lights) and have discovered that the wire from (I b
You have 2-gang switch.
Look at following illustration showing gang switches:
http://waterheatertimer.org/How-to-wire-switches.html#gang
Hot wire feeds one screw on first switch, and then jumpers to second switch.
Your jumper wire is connected wrong place.
Find hot wire... there will be 1 hot wire entering gang box.
Disconnect all wires, and separate for testing.
Turn power on and test each wire to bare ground wire... that will show the hot wire.
Sorry it is difficult to post question on fixya, or communicate with people answering free questions.
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 08, 2014 | Electrical Supplies
I am trying to wire a three gang box that has 15 amp power into it which has a porch light a outside light and a out side plug. i have a black and red comming in which is hot.how do i connect this...
Copy following links:
http://waterheatertimer.org/images/3-gang-box-800.jpg
You have to test which wire is neutral.... usually white wires twisted together and covered with wire nut in back of box.
Hot wire with test 120volt to neutral.
Hot wire will test 120volt to ground.
Gene
h
Sep 05, 2013 | Cooper Industries Cooper Wiring 2158V 3...
2 gang light switch wiring diagram
I'm sorry, maybe I'm not understanding correctly and completely. First, I'm assuming you're installing a two gang box to replace an existing single. If not and you have two red and one black terminated to your existing switch, all you should have to to is; kill the breaker, remove the existing switch, get a couple spare pieces of black wire, just to keep things consistent, splice the three black wires together, terminating one on each switch, top or bottom doesn't matter, and carry one red to each switch. That's about as simple as I can explain it. From everything you've said, your black sounds like your hot wire, and your reds go to either light fixture. This installation should work for you hope this helps!
Aug 19, 2017 | Electrical Supplies
Got three seperate lights want to put in into one thee gang light switch
Copy following link for wiring 3-gang switch:
Nov 19, 2011 | Home
How to connect three gang switch to control three lights, using two 1mm double core
What is 1mm double core?
Following image shows example 120Volt 4 gang switches with outlet.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
Each 120Volt electrical box has one Hot wire. This is true for ceiling and wall boxes.
Normally in a gang box, the Hot wire jumpers across all devices in the box.
Some switch boxes do not have Neutral wire. Neutral wires are usually white, and are twisted together and covered with wire nut and shoved to back of box.
Open following links for typical 120V and 240V circuits in US.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Feel free to add a comment and describe wiring, and voltage.
For example if hot wire arrives from one of the lights.
Describe the wires that you have, and what each wire goes to for best possible answer.
Aug 16, 2011 | Cooper Industries Cooper Wiring 2158V 3...
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I took a three gang face plate of now this switch is number 1 witch operates the hall number two switch operates the sitting room. number three operates the third light in the same room. but number three...
You need to determine where the power is coming into the box. That power line needs to be jumpered to each switch. The black of the lights will go to the other side of each switch. All neutral wires are tied together.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Oct 01, 2009 | Cooper Wiring Devices 3-gang Cooper Wall...
I am trying to install a 2 way gang switch, i have put the two red wires in the bottom terminals the black and yellow in the right terminals, but they are not working two way, i have a spare blue wire...
There is no simple answer. It all depends where your feed is and which switch is the "point". The point is the black wire bringing switched power to the fixture. Both the point, and the feed will be on the top black terminal on one or the other THREE way switches. The travelers go to the bottom two terminals and the neutral, usually white wire, just splices through. I hope this helps.
Sep 21, 2009 | Cooper Wiring Devices 2-gang Cooper wall...
Wiring two circuit pull switch boat lights
3 terminals.. 1 power input & 2 x outputs
Main positive goes to 1 terminal = power in to switch.
The anchor goes to another terminal = power out from switch to anchor
3rd terminal is another output for lights/anchor.
Mar 28, 2009 | Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
Home Logo
232 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
