Question about Whirlpool 24 in. ADG6340 Built-in Dishwasher
ADG 6340 WH light flashes 8 times. Programmer knob jumps from one programe to another once the tablet is dispenced. Please help
4 Suggested Answers
  • 1314 Answers
SOURCE: Dishwasher adg 6340
do you know how to use volt ohm meter your problem can only be two places either your timer is bad or your wash motor is bad un plug the wire at the motor set meter to volts take the connector after the water fills have some one turn the timer for you slowly if you get proper volts on your meter then open the door plug the connector back on the motor if the motor starts then the timer motor is bad if the wash motor doesn't run then its bad if you don't get no volts the contacts in the timer are bad now some timer motors can be replaced with out having to replace the whole timer
Posted on Apr 01, 2008
SOURCE: front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Posted on Jun 11, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I have a Whirlpool Dishwasher model no. ADG 6340
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Posted on Jun 05, 2011
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
Holiday mode refrigerator
If it is on Holiday Mode, press the key just once more. Page 8.
KitchenAid KSSC42QMS01 Use Care Manual
Jul 24, 2013 | KitchenAid KSSP48QMS Side by Side...
Knob keeps on rotating but it doesn't follow the program.it keeps on moving and jumping into another number.
So the timer Knob keeps on rotating click click ........forever.Do you have a red light flashing a number of times then light stops for 3 secs or so then flashes the same number of flashes again before it stops again for 3secs=a fault code.count the number of flashes very carefully.Usually,the pump is jammed or blocked but can be whole load of other things depending on the number of flashes!
Dec 29, 2010 | Indesit Washing Machines
04 Envoy xuv 4 wh. drv. stays in 4 wh drv. HI
Try putting your transmission in neutral and slowly shifting the 4wd selector to each position but you have to wait a few seconds between selsctions as it has to go through your vehicles computer, shifting to fast will cause your symptoms. I hope this helped you out. Roger
Feb 08, 2010 | 2004 GMC Canyon
Front light flashing
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool ADG 6340 Dishwasher
What flashing are you referring to ? This could very well be a fault code.
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool 24 in. ADG6340 Built-in Dishwasher Logo
57 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
