Question about Gateway Solo 5300 Notebook
The power on my laptop won't stay on
It is plugged in, but the green light keeps going off and the pop up appears "switch to a power cord."
if I jiggle the power cord, sometimes i can get the green light to stay on, but for only about 5 minutes, then it starts blinking again and eventually disappears.
could there be a problem with the part that plugs in to the laptop?
  • tinabina122 Jan 15, 2009
    Last month I stepped on the power cord, and yanked it out of my laptop. Now it keeps falling out and I even taped it on. I tried a different Sony cord and it didthe same thing , so the problem is with the port (hole). What can I do? I followed the link but it did not provide me with any info.  thanks in advance T
    Uploaded 30 video answers.
    Uploaded 5 video answers.
  • 72 Answers
The jack or AC power pin can be fixed yourself if you're up to it. The part is usually under $10. I've done three (2 Fujitsu' and a Sony. Take your time when you take it apart and take pictures of the disassembly. They will com in very handy when you start to put it all back together again. When you get it fixed invest in a proper cable retention device so the AC power pin doesn't get damaged again. This short Chris Pirillo Video talks about CRDs on laptops.
Posted on Jun 10, 2008
  • 187 Answers
It sounds like you've either got a faulty power supply, or a fault power jack (the jack is what your power supply actually plugs into on your laptop and is prone to coming loose). Usually you'll be looking at around £100 for a new jack, and depending on where you get it, anywhere from £50 for a new power supply.
Posted on May 26, 2008
On the power and reset it for 15 sec wait for the green to light up but the green light dont light up . keep lighting orange light keep on light up. pls help
switch off your printer. remove power cord from its main source and remove usb cable connection from printer to computer. wait for 5 minutes then connect back the usb cable to you computer and plug in the power cord ,switch on the printer
Sep 02, 2015 | Office Equipment & Supplies
Acer TimelineX 3820TG Will Not Power On
make this test and fix it. God bless you
Check your laptop's AC adapter. Ensure the laptop's AC adapter is snugly plugged into the port on the back of the . Also, check its connection into either the wall socket or the surge protector, depending on your setup. Make sure the AC adapter is securely in one of these outlets and not loose. Also, if the adapter is plugged directly into the wall, try another outlet. Your existing outlet may be blown.
    • 2
Check your monitor brightness settings. Sometimes these settings get accidentally turned all the way down, which results in what appears to be a dead laptop battery or malfunctioning power supply, but is really just a simple fix. Your laptop has dedicated brightness keys at the top of the keyboard, directly above the numeric keys. Adjust the brightness settings here.
    3 Look at the battery indicator light if your laptop appears to be out of battery or suffering a power failure. If it is not flashing or indicating a power problem, your laptop's "LCD closed switch" may be malfunctioning. This switch acts as a sensor which normally judges whether your laptop is open or closed. Sometimes this switch gets stuck in the "closed" position, resulting in the laptop believing it is shut and thus the monitor's back-light staying off. This switch is located right beside either the left or right hinge at the bottom of your laptop's display . Tap this switch multiple times with your finger to attempt to free it up and get it out of the closed position.
      • 4
    Consider whether your laptop's battery has completely died and needs to be replaced. Average laptop batteries last for approximately 1000 charges, after which point they either gradual deteriorate and have trouble holding a charge, or simply fail altogether.
    Eventually your laptop's battery will have to replaced, and if none of the other troubleshooting steps yielded results this is likely the source of your perceived power supply problems. Flip over your laptop and locate the horizontal outline of the battery, which will be at the top center of the bottom of your computer.
      • 5
    Notice the battery release mechanism on the bottom of your laptop, which should be directly below the horizontal outline of the battery. Slide this release mechanism to the left to disengage the battery and gently pop it out. The laptop's power supply may now be replaced.
    Jul 25, 2013 | Acer Aspire TimelineX AS5820T-7683...
    Macbook pro won't start/charge
    It appears as if your power supply is dead. The power supply is inline with your power cord and has a light on it, if I am correct. Since the green light was dim, then went out all together on your power supply, that would indicate that it would not take a charge any longer, and the dim light, down to none, was the rest of your battery draining. Assuming you tried multiple power outlets, my suggestion would to borrow a power source from a friend and check it, or go to best buy/Apple store and have them use one of theirs to see if it comes on.
    Sep 25, 2012 | Apple MacBook Pro Laptop Computer with...
    Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
    Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
    If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
    Good luck.
    Jul 16, 2011 | Toshiba Computers & Internet
    My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
    silly question sorry
    but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
    Jun 23, 2011 | Gateway M-6847 Notebook PC
    I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
    You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
    Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
    Console light stays green all the time.
    Your system's power supply cord could be faulty.
    it could be receiving too much current and its making your power supply think the system needs to stay on. try plugging your console into a different outlet or surge protector. if that doesnt work you will most likely have to get a new power supply cable.
    Dec 17, 2009 | Nintendo Wii Console
    Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
    try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
    try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
    if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
    Oct 12, 2009 | Dell Latitude D610 Notebook
    Laptop won't turn on/stay on
    Is the fan blocked?
    If no air goes in, CPU could overheat.
    Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
    Computers & Internet Logo
    1,182 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
