My screen flickers and appears as if it is going to go out. A couple of times, the screen would not go on at all. What could it be?
  • 787 Answers
Most likely, it is a video card problem. Test your monitor by plugging it to another computer and then check to see if the problem is still present. If it works fine on the other computer, then you need a new video card.
Posted on Oct 01, 2010
Hp officejet 8600 pro LED display flickers
This model has screen errors. You will need to exchange printer or change the screen on printer. Removes with three screws on top of the screen latch.
Jun 17, 2017 | HP OfficeJet Office Equipment & Supplies
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
Binatone sat nav - when I turn it on the screen flickers and all i get is lines going across the screen.
hi please try reseting the system and calibrate it a couple of times this should work for you goodluck
Mar 18, 2011 | Toymax Binatone Carrera X350 Car GPS...
How to solve laptop nx7300 screen flickering
sir try un-installed your video card then install angain.
Feb 22, 2010 | HP Compaq nx7300 Notebook
It flickers and turns off
Your unit is going out. What you need to do is simple just buy a new one. You won't be able to get that one fixed because no one repairs the screen only.
Jun 18, 2009 | Nintendo DS Lite Console
Sony vaio PCG-GRT30P Screen Problem
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
