Question about Casio EXILIM Card EX-S770 Digital Camera
This is an old problem of mine.. Every time i turn on the camera it open the setup menu, i have to adjust time and date every time before i can take photos, this is really annoying! Any help is welcome. thanks,
  • Amichai Oct 01, 2010
    Every single time, It is crazy, tried to reset it but with no success..
    Guru:
  • 194 Answers
Hello Amichai
Is this really every single time you restart the camera or only if you removed the battery when the camera was off?
Kind Regards
StephanSA
Posted on Oct 01, 2010
  • Stephan Reichert
    Stephan Reichert Oct 01, 2010
    The problem with a lot of digital camera's including my Kodak z712IS and your Casio EXS770 is that they don't have a internal battery to store the time and date like on a computer.
    My camera resets as soon as I remove the battery but your camera actually uses a capacitor to store a small charge which should be able to store the time for at least a few hours.
    It is however normal for your camera to loose it's time and date settings if the battery is removed and this cannot be remedied unfortunately.
    Please feel free to ask if you need more info.
    Kind Regards
    StephanSA
  • Stephan Reichert
    This is definitely not a software problem.
    The fact that this happens every single time indicates that the capacitor that stores the small charge to save the date and time has probably failed. The problem could also be with the small flash disk in the camera on which this info is stored.
    Neither one of these two are really cheap things to repair at about $50 min for each so the best advice I can possibly provide is just to live with it unfortunately.
    Kind Regards
    StephanSA
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Dec 14, 2010 | Insignia NSDSC10A Digital Camera
I have a kodak easy share M1073 and cannot figure out how to reset the date. I can turn the date stamp on and off but that's the only option I have.
It's important to set the date and time so that pictures and videos are organized by the date taken. The date and time procedure varies slightly between camera models, but generally:
  1. Turn on the camera.
  2. Press the Menu button.
    If you see a Setup tab, press the Right arrow button to highlight the Setup tab. If you don't see a Setup tab, press the Down arrow button to select Setup, then press the OK button.
  3. Press the Down arrow button to choose Date and Time (or similar), then press the OK button.
  4. Press the Right/Left arrow buttons to move between year, month, and date. Press (or press and hold) the Up/Down arrow buttons to scroll through the year, month, and date.
    Use the same procedure to set the time.
  5. When finished, press the OK button.
NOTE: If your KODAK Camera has a touchscreen, the same principles apply. Tap the Menu icon, Setup, then Date and Time (or similar).
Nov 03, 2010 | Kodak EasyShare M1073 IS Digital Camera
When I print photos, it doesn't show the date on the photo. Also , when I scroll down to Date/Stamp on the menu, it is always "off". And I can't change the setting. Help
You haven't said what make/model your camera is, so it is hard to advise.
Without knowing the camera, I am guessing that you may be in the wrong mode when trying to change this setting. You won't be able to change it while reviewing pictures already taken. You can only change it for pictures to be taken subsequently. Once pictures are taken, you won't be able to add the date stamp, nor remove it if it has been stamped.
It may be that it won't allow you to set this if you haven't already set the date and time in your camera. I can't see why this setting would be shown at all if it was not possible to turn it on (i.e. if your camera did not have this feature).
Nov 03, 2010 | Cameras
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
Change the date
-Turn On camera
-Press menu button to show an options screen
-Go to setup menu or a Icon of a Wrench thats the setup
-Under setup Press down arrow 12 times to show he date and time
-Press Ok buttton again if you already on the date and time to adjust the date setting and time
-Gudluck!
Nov 06, 2009 | Kodak Z8612 Digital Camera
Can adjust the date stamp but it doesnt show in the view window as being turned on, how do you turn it on?
Ok dont you I'l be happy to assist You.
first Turn On your camera
-Press Menu button scroll down using the directional button of your camera and look for setup and press Ok button
-Now you will be On setup menu press scroll down again 11 times now you will see the date stamp then Press Ok
-Now you may turn On now your date stamp., Gudluck!
Oct 26, 2009 | Kodak EasyShare Z740 Digital Camera
How do you change time on motorola w377 been through menu but cant find any way of changing time
In addition to what 'TERESACONSTA' said after you go to Setting, select Time and Date, if Autoupdate is on,take it off: this will open the sub menu to with;
Time
Date
Date Format
Autoupdate: Off
Now you can make your changes
Oct 25, 2009 | Motorola Mobility W377 Met Silver/Pink...
Unable to change the time settings
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
Sep 19, 2009 | Sony Cybershot DSC-S950 Digital Camera
Cannot set the Time/Date
Setting the Date and Time The date/time needs to be set if/when: Camera is turned on for the first time. Camera is turned on after leaving ViviCam X60 without the battery for an extended period of time. When the date and time information is not displayed on the LCD monitor, follow these steps to set the correct date and time. 1. Slide the mode switch to [replay ], and press the MENU button. 2. Select [Setup2] with the LEFT ARROW button. 3. Select [Date/Time] with the UP ARROW / DOWN ARROW buttons, and press the SET button. The Date/Time setting screen will be displayed:[Setup] [Format], [On/Off]. 4. Select [Setup] with UP ARROW / DOWN ARROW buttons,and press the SET button. Select the item’s field with theLEFT ARROW / RIGHT ARROW buttons and adjust the value for the date and time with the UP ARROW / DOWN ARROW buttons. The date and time is displayed as the format you set. The time is displayed in 24-hour format. After confirming all settings are correct, press the SET button. The setting will be stored and the screen will return to the Setup2 menu.
Jul 05, 2008 | Cameras
Casio Exilim Z57 Date and Language set up
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
Jun 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
27 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
