Question about Sharp R-1480 Microwave Oven
I have sharp microwave oven model R-231F. On digital display (which is suppose to show time) only 88888 is displayed. suspect fault with the PCB behind display or keypad. Please advise how I can obtain these spares or from where I can get the PCB/microwave repaired?
  • Sharp Master
  • 9,047 Answers
First I would suggest a "hard reset". Simply unplug the oven for a minute or two, then try again.
If it still fails, it may be that the keypad has failed, or there is a bad connection due to moisture, grease, etc.
This is an Australian model, so it's hard for me to give more specific information.
But one some US models the LCD and keypad connect to the circuit board via a rubber "zebra strip" and losing that connection can result in a loss of display segments and / or key response.
I've attached a diagram showing where one can clean to restore operation in this case.
Posted on Oct 02, 2010
  • Anonymous Oct 02, 2010
    My attachment seems to have failed.
    Try there:http://031d26d.namesecurehost.com/mwd/r3...
  • pbarj Oct 03, 2010
    Dear Guru,
    Thanks for your help. I have tried hard reset many times, but unfortunately it did not work. Now the problem is, when I had given PCB and display module to somebody to investigate, he has lost the flexible zebra strip. I have no idea from where I can get another one in Mumbai. If I can find a place in Mumbai, where I can get parts for Sharp microwave, it will help me a lot.
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
I also have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave part works fine otherwise. What part do I...
It is a display panel you require and you should be able to get a manual at the same time.
Try http://www.sharpdirect.co.uk/support/spares-and-accessories/page/spares/
Hope it is helpfull
Feb 27, 2011 | Sharp R-319FW Microwave Oven
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Digital lcd display need part number on sharp R-1200 shows digit 1 all the time
We regularly repair such control units for customers nationwide for $39.95 with a one-year guarantee.
The service manual is here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Apr 26, 2010 | Sharp R-530ES Microwave Oven
The display no longer works on my Model R303CW Sharp Microwave. Is there a part that will fix the display?? Everything else works fine.
Nope , could be dry joints or corroded pcb or defective display driver or supply ? Only can be told once opened and inspected.
May 13, 2009 | Sharp R-303CW Convection / Microwave Oven
Dim Display Panel on Sharp Convection/Microwave R-1851
its a common problem with the sharp microwaves. the control pcb needs to be replaced. it should come with the clock attached to it.
Mar 13, 2009 | Sharp Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
Jan 25, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp R-1480 Microwave Oven Logo
413 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
