Question about Hand Tools
I have 2 ryobi drills with18 volt batteries that dont hold their charge very well. although these drills are quite old, they work very well and are in good condition . the batteries are 18 volt ni-cad type bpp1815 with a number 0306 also on the batteries.can you recommend a solution thanks.
    Champion:
  • 225 Answers
The batteries are getting weak,I bet if you buy a new battery and fully charge it your drills will run like your used to.
Posted on Dec 28, 2010
    Problem Solver:
  • 5 Answers
While nicads dont last as long as the newer lithium, they are much cheaper since tehy ve been in production longer. A good source is Ebay. One item to bear in mind is to check your current battery specs for the amh level...its not just the volts you want to match up but also the amp hrs...hope this helps
Posted on Oct 19, 2012
  • 3 Answers
Your batteries are probably weak and need replacing. I would consider the new Ryobi Lithium batteries as a replacement.
The lithium batteries have no memory and do not lose a charge like the NiCad style batteries. The Lithium batteries will work in your older model Ryobi drills. You would however need a new charger for lithium batteries.I have provided a link to show you the different models. http://www.homedepot.com/webapp/wcs/stores/servlet/Search?storeId=10051&keyword=Ryobi+lithium+batteries&jspStoreDir=hdus&langId=-1&catalogId=10053
Posted on Dec 28, 2011
I have 2 ryobi 18 volt one + batteries won't charge, blinks red. I have 2 chargers, same for both. 65 degrees here so not too cold.
Just a thought, lithium batteries wont charge in Ryobi's old chargers. I upgraded my batteries but not the charger until I found this out.
Feb 18, 2017 | Ryobi Drills
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
My product wasn't listed ... My Ryobi 7.2v drill stopped working (8 yrs old). I bought a new battery, not including the charger cable, and it charges just a tiny bit. Should I replace the cable or buy a...
After 8 years its possible you have some corrosion or bad contact on drill, takeing it apart an checking inside may be to much for you,but make sure all contact are clean on outside.
Dec 18, 2010 | Ryobi Multi-Volt Battery Charger
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
Battery will not hold a charge
If the battery is one year old, it is shot. I have about 20 batteries under the bench and about 5 cordless drills , saws, lights, you name it , I won't buy anymore. I have a bunch of them, the batteries don't last. It is cheaper to buy a new kit with new batteries than to replace the batteries. No more.
Oct 24, 2010 | Ryobi 18v 38" One+ Cordless Drill P205 18...
My 14v ryobi charger is givig two lights when I am charging my battries. whats wrong ?
red is charging, green is done, amber is either hot or bad battery ive seen that with both symptoms when on with the green. dont run your battery down to the limit and always keep the battery charged this will prolong the life of the battery, dont store dead batteries in other words.
Jun 19, 2010 | Ryobi Multi-Volt Battery Charger
How to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
Oct 13, 2009 | Drills
Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Mar 16, 2009 | Ryobi Drills
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Hand Tools Logo
266 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Dan Apthorp
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
