Question about Panasonic NNH965BF Microwave Oven
When I operate my Microwave Oven, It did not rotate. Your help woukd be appreciated.
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 01, 2010
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
GE Profile Spacemaker Microwave Oven sparks at the center of the rotating rack. There is no sparking when it is removed. I removed and cleaned the wave panel, but that did not help. I will wait for your...
This has to be grease, food debris, or carbon, probably on the rotating rack.
Run the oven for a few seconds empty - with and without the rack - to find where it is arcing.
Then clean, sand, and repaint with high temperature appliance spray paint as needed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Tray is not rotating when the microwave is operating?
Basic Microwave Oven TroubleshootingTips
heatman101--=
Jul 16, 2010 | Whirlpool MH1150XM Convection/Microwave...
Daewoo rotating base
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
May 24, 2009 | Daewoo KOR-630A Microwave Oven
Ee5 ERROR CODE on r-22gtf
Your voltage selector is not set properly.
The R-23GT and the R-24GT have been preset for 230V operation.
If you need to change this oven for 208V operation, follow instructions below.
1. Unplug oven.
2. Remove one screw(A) from the Voltage Select Cover located on back of the oven near the bottom.
3. Remove the Voltage Select Cover and rotate 180 degrees.
4. Reinstall the Voltage Select Cover using one screw(A) removed in Step 2.
5. Plug power cord into wall outlet.
Your oven is now ready for 208V, 60Hz operation.
Feb 14, 2009 | Sharp R-22GT Microwave Oven
Broken rotating microwave arm - can't find part
That would be the support, and you can find it by entering your model number UMC5200AAS here.
Nov 22, 2008 | Maytag UMC5200AAS Microwave Oven
Jenn-Air JMC8100- Microwave
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 05, 2008 | Jenn-Air JMC8100 Microwave Oven
MS-3444DPS LG Microwave
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | LG LRM1250 Microwave Oven
Help inside tray will not rotate
check rotated plate and connecting surface ok.
Nov 12, 2007 | Emerson Black Microwave Oven
Panasonic NNH965BF Microwave Oven Logo
74 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
