Procedure of connecting samick mixer pm 4150s
What can you tell me about an Indonesian made Epiphone Invader S99010103?
Your guitar was actually made at the Samick Plant, Korea in January, 1999, before Samick moved its production to Indonesia and China.
An Indonesian made serial number should start with 'SI'.
Apr 06, 2017 | Epiphone Music
Hi any info date and value of this SAMICK strat guitar? serial number 5040105
Your best bet would be to contact Samick directly. Here's the link-
Samick Music Corporation
Feb 27, 2016 | Music
What Year is my Samick Guitar
I believe it to be a 2010 as some of samicks serial numbers start with the last 2 digits of the year it was made as the first 2 digits of the serial number. Hope that helps.
Nov 10, 2015 | Samick Music
How old is my samick guitar model LW-028 A. , serial 9705009773
Generally the first two digits in Samick instrument serial number is the year. 1997 in your case.
Mar 01, 2015 | Samick Music
Samick sm-10
Try using Google and search for it. enter Samick sm-10 in the search box.
Jun 14, 2014 | Audio Players & Recorders
Connecting Yamaha Mixer with Bose L-1 Amplifier
See this article about connecting a Yamaha mixer to a Bose L1
Mixer Yamaha MG8 2FX
or
Call BoseĀ® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them at the Bose Forum
Ask Bose for Help Forum
Apr 16, 2012 | Bose L1 Speaker
WE ARE EXPERIENCEING RADIO INTERFERENCE AND ARE BLOWING SPEAKERS, DO WE NEED TO HAVE THE MIXER AND EQUIPMENT ON UPS SYSTEMS WE ARE USING NADV AUDIO PM-200 A POWERED STAGE MOINTOR 115/230 VOLT SER#...
UPS will not help this. Make sure you are using GOOD quality balanced cables, preferably XLR to connect to powered speakers. Make sure ALL (read that "ALL" closely) of your equipment is powered from the SAME receptacle or power module... this means run power to your mixer or speakers alongside your audio lines or snake between the units. This includes ANY other devices tied into your mixer with the exception of truly ground lifted DI's.
Good way to pop speakers is to run them on stage power and mixer from plug at the rear of a room... The common mode ground noise will exceed the common mode capability of the audio inputs and fry them.
Nov 30, 2010 | Behringer XENYX 2442FX Mixer
Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Aug 10, 2009 | Audio Players & Recorders
Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Aug 04, 2008 | Wolfgang Puck Stand Mixer
53 people viewed this question
 Grubhead
Grubhead
