Question about Clarke Power Products 7 in 9 in Angle Grinder 15 Amp
Do you have a basic training course and knowledge assessment for 115mm and 230mm angle grinders
  • 487 Answers
Hi, a good place is youtube, there are videos on most tools and some very good tips.
Posted on Oct 01, 2010
What are the aim of SSSTS and SMSTS course?
The main objective of SSSTS course is to provide health and safety treatment. It can prove that you have knowledge of current health and safety laws and that you are suitable for the job.
May 16, 2015 | Computers & Internet
Grinding problem
That is a good idea. Also one or both brushes brushes could be stuck in the holder. If stuck I would just replace the brushes so I could count on it working a long while.Give the brush holders a good cleaning if you decide to replace or not.
Aug 03, 2014 | Dewalt D28493N 9" 230mm Large Angle...
Grinder makes a scraping sound
They all make a funny growling noise while they're running. It's just a rough fit in the gearing.
Jan 25, 2014 | Dewalt D28110R Heavy-Duty 4-1/2" 115mm...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
How do I remove the disk from a Makita 9009B 230mm Angle Grinder
The locking nut undoes in the same direction as the blade spins. It's done now!
Thanks
Apr 02, 2011 | Makita Angle Grinder
I have a Dewalt Angle Grinder (4 1/2'' D28402) Checked that I have the O rings and don't see anything missing....don't know why but blade won't tighten down (unless I put the tightening wheel, wheel side...
What do you mean wheel side out? It should look just like the picture, the nut side of the disc threads on first. Depending on what disc you want to put on you may need a spacer that goes on first and then a threaded washer on the outside.
Jul 08, 2010 | Dewalt D28402 412" (115mm) Small Angle...
Fault on a Kinzo 115mm Angle Grinder
Hi J,
Hopefully you just wore out the brushes. Replacement kits are available for a few bucks and the fix is pretty easy.
On the darker side, If it overheated enough that it burned the windings (insulation melts, shorts, badness), there isn't much you can do unless it's still under warranty.
You won't know until you get it apart. You'll know which it is at a glance.
Unplug it and dismantle the base of the grip where the cord is attached.
The brushes are small spring loaded graphite blocks that transfer electricity to what looks like a cylinder around the central drive shaft that has a lot of vertical copper strips on it. They are normally housed inside small copper tubes opposite each other.
If those tubes are empty but for the spring, it's brushes.
If the insides are full of ashy residue, it's not the brushes
Best regards and I hope it it's the brushes
Mike
May 27, 2010 | Dewalt DEWD28110 Heavy Duty 4 12"...
I have a brand new Grinder 230mm and now need to change the grinding disc however I cannot get the locking flange off - I have detroyed one spanner, and purchased a stronger one, but still no good. can...
Try turning it the opposite way. Instead of loosening it, you may be tightening it. Reverse threads on these machines are necessary to keep the flange from flying off by itself. Joe
Apr 12, 2010 | Black & Decker 9"/230MM 5,000 Rpm Large...
Clarke Power Products 7 in  9 in Angle Grinder 15 Amp Logo
93 people viewed this question
Top Clarke Power Products Saws Experts
Tom Chichester
ray gallant
Are you a Clarke Power Products Saw Expert? Answer questions, earn points and help others
