Question about Fellowes SB-99Ci Shredder
Fellowes SB 99 C, bin full light on despite emptying. Where is sensor for cleaning? Telephony office where deal with copiers, computers, and office systems but this is not obvious!
SOURCE: Shreds halfway, then stops. Fellowes SB-95C
on the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Posted on Feb 05, 2009
  • 105 Answers
SOURCE: The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Posted on May 14, 2009
SOURCE: Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Posted on Jul 07, 2009
  • 105 Answers
SOURCE: the basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Posted on Sep 18, 2009
  • 105 Answers
SOURCE: Unit runs for 4 seconds and then shuts down
there are led sensors on the bottom of the cutting head above the bin . they are either dirty or defective.
Posted on Dec 04, 2009
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
We have a Fellows Pwoershred 2200SC that keeps showing the full bin light even when it's empty. Tried cleaning the eye near the feed area with canned air as per recommendation by a shredder maintence...
There are also sensors under the shredder head to indicate when the bin is full. You either have a defective sensors or a dirty one (clean with air).
Aug 29, 2011 | Fellowes 2200SC Shredder
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
Model C-480C, always says bin is full! Where is the sensor?
Look up under the cutter asm and remove the paper shreds that are stuck in the blade assembly.Also clean the sensors with air or cotton swab.
Jun 03, 2009 | Fellowes Manufacturing C420 (Strip-Cut)...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Mar 26, 2009 | Fellowes Office Equipment & Supplies
Fellowes S8-*5c
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
The bin is full light remains on even though it's empty. How to I get it to work correctly?
Dec 24, 2008 | Fellowes Manufacturing Powershred SB-97CS...
Fellowes SB-99Ci Shredder Logo
117 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
