Question about Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter
RICOH - RL5C475A model PCMCIA adaptor connected system is not getting shutdown. restarting automatically. pls help
I have an Asus G60 laptop which was connected wirelessly to the internet. After a disconnection (router went off for a minute), the laptop no longer recognizes the wireless connection. The light on the...
Do you have PCMCIA adaptor or buil-in adaptor? If is pcmcia then unplug from computer, restart computer, after this shut down, plug your pcmcia and start again.
Mar 03, 2010 | Zonet (zew1600z) 802.11g/b Wireless...
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Sony vaio pcg-k25 won't stay on after pressing the power button. it powers up to the window to enter my password then turns off on it on. sometimes won't even reach that far, just the led lights go on than...
Please perform the following troubleshooting:
(i) Remove and reseat the RAM modules.
(ii) Remove the Battery and reinsert it after cleaning the metal contact.
If the issue persists even when the AC Adaptor is connected then try to get into the BIOS and check if the Computer restarts or shutdown automatically. Restart the Computer and press the F2 key as the VAIO logo appears to enter into the BIOS window. if the Computer shutdown even when in the BIOS then service will be required otherwise try reinstalling the Operating System.
Jan 22, 2009 | Computers & Internet
Hi usama
Look on EBay for one. You might find one on there. You might be able to get away with using a 64mb compact flash card with a pcmcia adaptor as well as a SD card. It can't be any bigger than 64 mbs.
Search under Ricoh memory cards.
They use PCMCIA as well. If you don't have a notebook with pcmcia you will have to get an adapter card for PCI use on a desktop.
Sep 12, 2008 | Office Equipment & Supplies
No wifi
You need to get a wireless adaptor your laptop did not come with wireless built in. You can get a USB adaptor or a PCMCIA adaptor. Either will work but the pcmcia adaptor will be a little faster
Have a look here
http://www.google.com/products?hl=en&q=pcmcia+wireless+card&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Hope that helps
Aug 25, 2008 | Compaq Presario Notebook
Bicu firmware update
You can check on copytechnet.com on how to get it. Heres what I know about it as a copier technician.
Ricoh provides the firmware upgrades to their technicians. The firmware has to be decrypted using a special program the runs about $300 from a company in Germany. Its a proprietary archive file that gets decrypted and put onto a pcmcia memory card. You can find them on EBAY. It has to be 64mb in order for the copier to read it. I tried using a compact flash memory card connected to a pcmcia card and I didn't have any luck using it. The utlility program can lock up the notebook computer as well if it isn't setup right. You can get a pcmcia card reader for a workstation as well. Ricoh used to make those for that particular reason.
What version is it at right now?
Aug 23, 2008 | Ricoh Aficio 1013 Copier
RJ45 Cable Adaptor for a NetGear FA410TX
You can get replacement dongles for your card at http://www.buynetgear.com or you can call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-888-305-7440cb_transparent_r.gif Monday - Friday 8AM to 10PM Eastern Standard Time.
Jun 05, 2008 | Computers & Internet
How can I connect a wireless adapter to my toshiba portege 660 cdt as there is not a port on it for the usb to fit in to
I am assuming that your wireless adapter is USB and that your Toshiba Portege 660 CDT has a PCMCIA slot. If yes then you would need something like a PCMCIA USB 2.0 Card adapter as shown here. The added advantage is that you would have an extra USB port. Just pls make sure that the PCMCIA USB 2.0 Card adapter you will purchase is compatible with your laptop and has drivers appropriate for your Operating System.
Alternately, you can try swapping your USB WiFi for a PCMCIA version similar to this. Again, pls make sure that the PCMCIA Wireless network card you will purchase is compatible with your laptop and has drivers appropriate for your Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 09, 2008 | Computers & Internet
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Open Questions:
I have a PCMCIA adapter, the RICOH R5CA475 based thing. It causes this problem under LInux: Dec 21 00:13:10 who7 kernel: Linux Kernel Card Services 3.1.22 Dec 21 00:13:10 who7 kernel: options: [pci] [cardbus] [pm] Dec 21 00:13:10 who7 kernel: Intel ISA PCIC probe: not found. Dec 21 00:13:10 who7 kernel: Databook TCIC-2 PCMCIA probe: not found. Dec 21 00:13:10 who7 kernel: Yenta ISA IRQ mask 0x0000, PCI irq 10 Dec 21 00:13:10 who7 kernel: Socket status: 30000810 Dec 21 00:13:11 who7 cardmgr[2550]: watching 1 socket Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0c00-0x0cff: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0820-0x08ff: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0800-0x080f: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x03e0-0x04ff: excluding 0x4d0-0x4d7 Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0100-0x03af: excluding 0x378-0x37f Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0a00-0x0aff: clean. Dec 21 00:13:11 who7 kernel: cs: memory probe 0xa0000000-0xa0ffffff: excluding 0xa0000000-0xa0ffffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff Dec 21 00:13:11 who7 kernel: cs: warning: no high memory space available! Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0d0000-0x0dffff: excluding 0xd0000-0xdffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0e0000-0x0effff: excluding 0xe0000-0xeffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0f0000-0x0fffff: excluding 0xf0000-0xfffff Dec 21 00:13:11 who7 kernel: cs: unable to map card memory! Dec 21 00:13:11 who7 kernel: cs: unable to map card memory!
Feb 27, 2017 | Ricoh R5CA475 PCMCIA to PCI Interface Card...
Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter Logo
478 people viewed this question
Top Ricoh Computers & Internet Experts
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
