Question about Car Audio & Video
My Suzuki Liana 2004 suddenly overheat than for 3 to 4 days work just fine than it overheat , i mean it doesn't overheat all the times ..please help me figure out what's wrong with my car ?
When it over heats does it backfires and engine stops?
Posted on Dec 20, 2010
Hi I have a Suzuki liana gl 2007 and have put two new radiators in it the still leak at same place can u help please
where is it leaking
obviously not from the radiators
have a pressure test done on the cooling system to find the leak
May 09, 2017 | Suzuki Cars & Trucks
Do you have to take front timing cover off to take the head off suzuki liana 2004 m18a? Thanks
sure.
how else could you free up cam drive?
and is VVT head. twin cam DOHC.. and belt drive.
car is European sold, we dont get those here. we get J20b engine.
and is same answer.
Jan 07, 2017 | Suzuki Cars & Trucks
Where is crank sensor liana 1.6
welcome to the USA forum , is your car USA.
no.
my guess is it has the M16a engine
see bottom left CKP #5
The M class engines , its on the PULLEY side
and facing said pulleys, (regardless of car it is)
its to the right of the pulley
that means the crank tone (teeth) wheel is behind said pulley on end of crank shaft.
we do have swifts here with m15 or M16
Aug 24, 2015 | 2005 Suzuki Liana 1.6
About suzuki liana
I haven't seen or heard of common problems with Suzuki. Their parts wear out like the others. Only thing I don't like is having to buy about every part for a Suzuki from the dealer. Not much after market parts out there for Suzuki.
Mar 09, 2015 | 2005 Suzuki Liana 1.6
Where in suzuki liana 2004 is the rear left window fuse
old post
electric window fuse. the fuse box is clearly labled,, miss that?
we dont have Liana, here,
so where are you., the manual and car vary by country sold.
go to suzuki and ask for a FSM,factory service manual.
if doing DIY serious work.
you could just check all fuses in 5min flat.
and that ends this search. fast.
so?? I use a thing called voltmeter. if all fuses have 12v on both
ends, key on, the fuses are all good.
then check for 12v at the dead motor. active.
1: got 12v, yes, motor is bad, no it ,just makes funny noises.
if motor makes noise, the window is jammed. check it now.(guides)
2: no 12v?, backup to switch, its failing.
ok 3 ways answered.
Jul 12, 2014 | 2005 Suzuki Liana 1.3
On my suzuki liana 1.6 2004 the airbag light keeps on
that means there is a fault in this system.
we scan it and read the Bxxxx codes.
in the suzuki shop (LOL finding one) the use a special factory SRS air bag tool.
my fancy scan tool can not do Suzuki/s
so take it in and get it scanned, by any shop with a SRS scanner that works in suzuki,
Feb 26, 2014 | 2005 Suzuki Liana 1.6
My Liana got a problem of Back fire I changed ignition coil first then i Change their complete head but problem remain same?
Back fire back to where, the intake or exhaust.
intake backfire is a pop sound, not too loud, and is bad timing.
exh backfire means, fuel plus air is in the exh.
and explodes with a loud report , we call it muffler explosing to help
with clear meaning.... in this latter example
you have a bad running motor (rich as pig) a dead CAT and exhuast air leak
all at the same time.
Mar 29, 2013 | 2006 Suzuki Liana 1.3
Engine light on
The P0705 means Transmission Range Sensor Circuit
Malfunction (PRNDL Input).
autocom cdp pro 3 in 1
Aug 24, 2012 | 2005 Suzuki Liana 1.4
How do i fix the central locking on suzuki liana changed battery now not working
When I use the key fob to lock or unlock the car. All the doors work apart from the drivers door. It works fine with the key in the lock? Help!!
Dec 20, 2010 | 2003 Suzuki Aerio
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
