Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
D-LINK G624T after saving parameters doen't answer anymore. Reset don't change anything. Wireshark doen't see anything from the router... Any advice ?
    Novelist:
    Habit-Forming:
  • D-Link Expert
  • 199 Answers
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Posted on Jan 06, 2017
4 Suggested Answers
  • 11 Answers
SOURCE: Not saving my settings
Under normal circumstances, you should never have to reset your router. If you have problems, usually you unplug it, wait a few seconds and plug it back in. You DO NOT press the reset button. If you are not pressing the reset button and only unplugging it and still losing your settings, it is a faulty router, exchange, refund is your best option. If you ARE resetting it, then it is doing exactly what it is supposed to do.
Hope this helps.
Posted on May 19, 2008
govinda123
  • 2260 Answers
SOURCE: Pleasssssssssse help : on router G624T
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Posted on Jan 11, 2010
elix0411
  • 3530 Answers
SOURCE: I have a d link
Welcome to Fixya
Try to turn off/on the dlink router first. Reisntall the driver of your ethernet adapter. check your computer's IP address by going to command prompt and type in ipconfig. This is to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router. If you have 169.x.x IP address, Reboot your computer, router (if present) and broadband modem together, then re-test your connection. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
Thank you for using Fixya!
Posted on Dec 26, 2010
IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Sep 10, 2012 | Computers & Internet
I have d-link router ,works fine ,my new laptop hp don't connect to interent ,see the network ,but unable to connect
Hi amany91,
There might be an issue on your wireless connection security settings. I would advice resetting your router to remove the password and to restore to factory settings. To do that, look at the back of your router and look for the RESET BUTTON. Then using a pin, press and hold the reset button for about 10 seconds. After resetting it, restart your laptop and then try connecting to your router again.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
ternet again.
Oct 09, 2011 | D-Link DIR-615 Wireless Router
I cannot reset my router. Everytime I configure or set-up it always prompt me "Need user name & password".
If you forget the username or password, or if the configuration becomes really messed up, you can always clear all the non-volitile parameters by doing a 'factory reset'. To do this, with the router already fully booted, press and hold the reset button for 5~6 seconds and release. The router will boot back up and answer to 192.168.1.1 just as if it had just been flashed with DD-WRT.
May 26, 2011 | D-Link DIR-600 Router
I DON T KNOW HOW TO CHANGE THE SETTINGS ON MY ROUTER SO THAT IT CAN CONNECT WITH MY WII. THE ROUTER AND THE WII ARE COMPATIBLE BUT IT SAYS TO CHANGE THE ROUTER FROM 6 TO EITHER 1 OR 11 BUT HOW DO U DO...
Go to your router's Web Utility, if possible through a computer connected to the router by cable (because you'll loose access to the router once you change its encryption rules). If you haven't changed the access parameters, the default IP address is 192.168.1.1, with 'User Name' left blank, and 'Password' set to 'admin'. In the 'Wireless' tab. I supponse you already have encryption definitions there. Try to set your 'Security Mode' to 'WPA Personal' and 'Algorithm' to 'TKIP'. Chose any 'WPA Shared Key' you want (from 8 to 63 characteers), and set the 'Group Key Renewal' parameter to 0 (zero, i.e. no key renewal, at all). Save your settings.
You see, my router is not Linksys, but in essence, the encryption parameters are quite alike, and this is how I managed to provide internet to my son's Wii console.
Hope it works for you.
Regards, Carlos
May 27, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Jan 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Cannot change settings on setup wizard
after u do the setting make reboot then u your setting will be saved otherwise u be facing the problem again and agian
Mar 26, 2009 | D-Link AirPlusG DI-524UP Wireless Router
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Nov 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Epson rx560 won't align to print on cds properly anymore
you can download the latest driver from here http://driverscollection.com/?H=Stylus%20Photo%20RX560&By=Epson click the link directly and select your operating system.
Sep 30, 2008 | Epson Stylus RX560 All-In-One InkJet Photo...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
178 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
