Question about HP Compaq nc4400 1.83GHz Core 2 DUO T5600 1GB 60GB 56K 10100/WIRELESS 12.1" XGA LCD Windows Xp Pro PC Notebook
My hp nc4400 notebook keyboard suddenly stopped responding. while i restart getting sound.
4 Suggested Answers
thumu
  • 69 Answers
SOURCE: HP Compaq nx6115 PC Notebook : Speakers suddenly stopped working
This is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue. I would like to provide my solution on the issue.
Well, this is issue not a hardware issue since you are able to hear sound by Ear Phone. This is an issue with either Conflict of IRQ or could also happen with driver of Audio is not working fine.
Please open the below link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00833257&lc=en&cc=us&dlc=&product=3256602
it is an HP article that is applicable for Notebooks with Windows Vista... this article helps to resolve the issue related to Sound...
In Most cases the issue will resolved once if DRIVER of SOUND is uninstalled from Device manager and then by reinstallation...
I am sure that this will resolve the issue.
Note :
If you are using Windows XP, please let me know so that I can search for article for Windows XP and provide you solution...
if you have any queries on the issue, you can mail me at thumuvikram@rediffmail.com. I'll be glad to help you!!!
Bye...
Posted on Feb 25, 2008
hapndnvegas
  • 35 Answers
it is the ribbon cable for the daughter board on the top panel. This controls the power button and the top speakers. The place it is located in is subjected to extreme heat and bending from pressing the power button too hard (engineered obsolesce just bad engineering take your pick) anyway the fix is as easy as removing the 5 screws under the battery and the one screw under the memory cover with the keyboard symbol on it. I will find a replacement on line or in my closet full of junk seems pretty standard flat ribbon cable. This problem could be covered under warranty with HP if your laptop is within the guidelines on their website for the recall. the recall is for power button issues and this is the next problem your going to have making your laptop useless. All you have to tell them is the power button works intermittently (now that i think about it mine did have a problem turning on sometimes) not any more. I just borrowed the cable that went to the crappy quick launch mute and volume controls untill i can find a replacement
Posted on Mar 26, 2008
  • 51 Answers
SOURCE: keyboard stopped responding on reboot after
Try booting into safe mode and then uninstall it and reinstall it from there. Safe mode runs only certain processes, in which case if there is any interference coming from your card in normal mode, it won't have that in safe mode. If the problem persists - and the machine does not have any malware infections that may cause this problem, contact the supplier of the card to see if there is a bypass around this supposed incompatibility issue. If my ideas work, please do rate me. Thanks.
Posted on Feb 05, 2010
The keys on my wireless HP keyboard suddenly stopped working. None of them work.
Have you tried changing the batteries? Also, you may have to re-sync the keyboard with the receiver.
Feb 08, 2015 | HP Computers & Internet
Nc4400 mass stroage control driver
download drivers from below link for your required OS
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome?sp4ts.oid=3239132&ac.admitted=1415617581095.876444892.199480143
Aug 25, 2014 | HP Compaq nc4400 Notebook
My daughters notebook wont load windows correctly
this happens when the RAM of that machine is either loose in the socket or has rusty connections, try fixing this and the machine will be just fine..... :)
Dec 25, 2011 | HP Compaq nc4400 Notebook
I have purchased (Sept 2011) a reconditioned HP NC4400 (without instruction manual) that will not connect to my existing Internet (wireless). I used Help (Intel (R) Wireless Troubleshooter) on the laptop...
Hi Steve,
The wireless switch would absolutely have an effect on whether your WIFI was ON on your laptop. The following link shows a diagram of your laptop:
http://h18000.www1.hp.com/products/quickspecs/12448_na/12448_na.HTML
It appears that it is a button on either the left edge of the laptop, or possibly above the keyboard. Press the button and ensure your WIFI LED (front-left edge) should be lit. Then, try connecting to your wireless network again. I hope this helps!
Sep 21, 2011 | HP Compaq nc4400 Notebook
I dont remember power on password for hp nc4400
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a ? 162 System Options
not set? message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
12.It should work....
Apr 08, 2011 | HP Compaq nc4400 Notebook
My hp compaq nc4400 does not detect its hdd
Hi
you could try this it sometimes work
turn off laptop and unplug power cord
turn laptop upside down
find the panel underneath that holds the hard drive usually 2 screws
remove panel and remove the hard drive
If you are not sure how to remove the hard drive ( not difficult )
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01884372&printver=true
turn laptop up correct way and try to restart laptop
it wont start up because you have removed the hard drive
now switch off again
turn upside down again
replace the hard drive
replace the panel
turn up correct way
and try to restart the laptop again
if this dont work
now turn off and on again pressing the F8 tab a few times to see if it takes you into repair options
and try the back to last known good configurations
or try some of the other repair options
hope you get it sorted
many thanks
Mar 22, 2011 | HP Compaq nc4400 Notebook
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
My hp pavilion dv2000 quickplay buttons at the top of my keyboard all of a sudden stoped working. I volume doesnt work. the play button, stop, next, back buttons as well. I dont know what to do and I...
Go to Control Panel and open 'Add/Remove Programs' or 'Programs and Features' depending on the OS you have. Remove HP Quick Launch Buttons. Restart your PC. Go to C:\SWSETUP and install the HP Quick Launch Buttons software. If the installation prompts for a restart, do it and then try using the buttons.
If you still have problems, report back.
Nov 25, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Compaq nc4400 1.83GHz Core 2 DUO T5600 1GB 60GB 56K 10100/WIRELESS 12.1" XGA LCD Windows Xp Pro PC Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
