Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Leaking water from the left side - Hotpoint 23 in. BFI62 Built-in Dishwasher
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Oct 01, 2010
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
Apr 09, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Leaking water from the bottom on the freezer side. It's a side by side refrigerator and is set up for water/ice on the front left(freezer) side but this has been disconnected and is not in use. Water...
check this website repairclinic.com they are talking about a clogged drain plug for the defrost cycle. seems we have exactly the same situation. see if this helps
Sep 24, 2009 | Kenmore Refrigerators
Water leaking from left side of frezzer out the
There is a restriction in the condensate drain. You should be able to press a piece of tubing against the drain opening (inside fridge) and BLOW (NOT ****) through the other end. this should clear the obstruction. The obstruction would be slimy goop, sooo again -
NO ****!
Sep 15, 2009 | Jenn-Air Refrigerators
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Leaking water
take the front off and the top up and on the left side there is a injector that needs replaced
Nov 28, 2008 | Washing Machines
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
111 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
