Question about Mitsubishi WD-65731 65" HDTV
Color/Pic problems Mits WD-65731
Recently, my TV will randomly start flickering and the color gets distorted, almost looks like a strobe light. Does anyone know what this could be? Lamp? Light engine or wheel? I want to get an idea before I start calling local techs. Already spoke to Mitsubishi and only could recommend local techs. I want to get as much info as possible before I call local techs. I feel like they will charge me to look at the TV but won't be able to fix it. Basically am anticipating aggravation on trying to fix the TV. How about pricing? Anyone have an idea on how much these parts are? I'm already aware about how much the lamp is, but am concerned about how much these other parts? Thanks in advance for any info
  • Anonymous Jun 08, 2008
    Our TV is doing the same as yours. Along with this, skin tones are blue. Looks like watching the Smurfs. Called Mits. Got the same, just gave me the number to a local service rep. We've only had ours a year and a half.
  • 2,920 Answers
It sounds as though there is a problem on the main board and yes,it will be expensive to repair.i would guess between 400 to 600 possibly more depending on how much damage is on the main board. i know this isnt what you want to hear but i have a friend that has a tv repair shop and i know he gets big money for repairs on big screens.
Posted on Aug 17, 2008
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
My WD-52725 mitsubishi 52 in tv is not working i turn it on and the fan starts but then i get a whining sound for about 5 too 10 seconds then it stops the sound for cable is working but no pic. then the tv...
This sound is an indication that the color wheel is faulty in the light engine, with mits sets you must replace the entire optics engine. You can purchased used light engines or have your sent in for repair. Try this site for rebuilt engines
Mar 10, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Tv started to shut off here and there, then the
Hi,samsung has 3 major failures.The 1st one is the lamp, which averages 6000-8000 hrs 2-4 yrs.When it's about to go bad it shuts off and on or image won't come at all.You can find your part here: Another problem that causes tv to shut off is the ballast,which is the board that powers the lamp.It makes clicking sounds and will cause pic to flicker.The other problem is the color wheel .The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Have a bless one!
Apr 12, 2010 | Samsung HL-S5086W 50" HDTV
TV has distortion very small on top and bottom which will flicker
This tv has two common problems:
in the power supply (set does distotions and shakes a lot etc very unstable until the set cannot work at all).
powerfully color gets back with a deep clean in the reflexion area. I'm sorry this job is for a technician, The set is so intricate for those two problems that any bad movement in this precision job could send the tv straight to wherever is bad.
Apr 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Distorted colors on my mitsubishi wd-73727
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Apr 02, 2009 | Mitsubishi WD73727 73" HDTV
Wd 62327
1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Jul 31, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-65731 65" HDTV Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
