Question about Pitney Bowes AddressRight DA300 Printer
Printer will not print the address onto the envelopes, it just keeps flowing them through
  • 126 Answers
The envelope size is not selected in the printer properties. check the settings in the print properties and select the paper type as envelope and size of the envelope.
Posted on Oct 01, 2010
How to print envelopes on canon mf6590
The way I do it to create in Word 2007 envelops. While a letter is still displayed look for Create button and select Create envelops. You select the dimensions of the envelop and the way it is fed. You will need to try a few times to be sure it comes out correctly.
Dec 27, 2013 | Canon imageCLASS MF6590 Copier
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
How to type an address onto a std bussiness envelope
Insert the envelope vertically. In your word processing program you should have an option for printing envelopes; usually in the TOOLS menu. Your program will figure out how to center the text.
Jun 22, 2009 | Epson Stylus C120 InkJet Printer
Print name and address onto envelope
Start by selecting the information, i.e,, highlight, then "CTRL+C" When you open the envelope window click into the address box, and use "CTRL+V".
In Word you simply select the information you wish to print, then click on the "Tools" tab, select "Letters and Mailings", and follow it to "Envelopes and Labels". When you open the last tab the information (address) will already be there.
Jun 19, 2009 | HP LaserJet M1522n MultiFunction Printer
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
My HP 1350 will not print cards/envelopes from the right side of the printer. They have to be loaded on the right but the printer keeps printing in the center.
Printing envelopes with an HP 1350:
If you use MS Word, select ENVELOPES. When address window appears, select OPTIONS on right > select PRINTING OPTIONS > select FEED METHOD option on far right (envelope placed on right of tray face down); select FACE DOWN; select FEED FROM UPPER TRAY. The only problem I have with this is that the address prints off in the lower quarter of the envelope rather than in the center of the envelope as we would write it manually. I am currently working on solving that problem.
Mar 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Printer keeps printing the same address on envelope
You need to restart the printer some times happens if the buffer gets full.
Dec 15, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Addressing envelopes
Go to printer folder and Cancel all pending jobs
Turn it off the printer and restart your computer.
Turn it on your printer and
Start over again
Use some program to print the envelope (like MS Word)
Oct 04, 2008 | HP LaserJet P2015dn Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Pitney Bowes AddressRight DA300 Printer Logo
97 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Victorman
Victorman
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
