Question about Pioneer GM-X924 Car Audio Amplifier
Pioneer GM - x924 amplifier . I lost the manual and i dont know how to connect to the car
SOURCE: Pioneer GM-7200M 800 Watts Mono Amplifier
i have this amp and i use 4 gauge power and 4 gauge ground
Posted on Apr 12, 2008
SOURCE: i have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
Posted on Sep 25, 2008
imadejoolaff
  • 27 Answers
SOURCE: gm-a120 how can i instale in my car
Hey Alexis! Not very much information can be found online for your specific model, however, this website gives general setup instructions for car stereo amps. Your model doesn't seem to have anything out of the ordinary so hopefully this guide helps you out some!
Posted on Mar 01, 2009
cortez_marco
  • 58 Answers
SOURCE: gm-a120 how can i instaled in my car
How to install an Amplifier:
1.) Disconnect the battery terminals: Just be safe. Do this.
2.) Run the power cable from the battery to the location of the amp or distribution block. (To read more about running wires, click here)
If you run it through any sort of sheet metal, be sure to protect the power cable with a rubber grommet, or some other protective device.
Be sure you have plenty of slack at both ends of the cable. This will make your life easier, trust me!
Be sure you run the power cable away from any RCA cables. I usually run the power cable down the side of the vehicle that the battery is installed on, and run the RCA cables down the center of the vehicle.
Once the cable has been run and secured, leave it alone for the time being. Don't hook it up, cut it or do anything else with it!
Be sure the power cable is secured with wire ties or some other means, BUT! Not until you have run the cable, and determined that the cable is going to work out where it is located.
3.) Find a suitable ground point close to the amplifier
This point should attach to the vehicle's chassis, and be a solid connection.
Run your ground cable from the amp (or distro block).
Just like with the power cable, this wire should be secured and protected. It should not be installed in a location that will distress it.
Use a piece of sandpaper to remove any paint or finish from your ground point. Use it to also sand away any rust or residue on your ground point. You want a good solid connection, so you'll want to see nice shiny metal.
Prepare an appropriately sized ring terminal
If your ground cable is going to be attached with a ring terminal (the most recommended means), attach it now. Remember! Do a good job here. We're looking for a strong, solid electrical connection. If you can use solder, I would recommend it!
Use a washer when attaching your ring terminal to your vehicle's chassis.
Finally, cover the ground point with something non-conductive. Also, Find some spray paint or finish that will protect your ground point from rust.
4.) Be sure to run RCA cables and the remote turn on!
Pull your head unit out of its mounting location.
If it's not already hooked up, hook up your remote turn-on wire to the head unit's wiring harness.
Determine which RCA cables will go to each channel on your amp(s). I find it useful to have a 4-channel cable and an additional 2-channel cable for your subwoofers. This makes it easier to run all of the wires at once.
Run your RCAs and remote turn-on. Keep the RCA cables away from any sort of power cable, especially the power cable for your amp(s). It's OK to run the remote turn-on wire with the RCAs.
Make sure all cables are secured and not installed in a way that will distress them. Be sure they aren't pinched, scraped or kinked during any sort of driving activity. In any places where they'll need protection, be sure to cover them with a tough material.
5.) Run all of your speaker wires.
Now it's time to run more wires! Run speaker wires from your speakers to your amp's installation location.
Just like with all of the different wires above, be sure they are secured and protected.
6.) Hook up all of the wires at the amplifier!
Hook up the RCAs, speaker cables, remote turn on, power then ground.
7.) Hook up a fuse holder near the battery.
Be sure you have this piece of equipment (and a fuse) before you even attempt to hook your amp up to your vehicle's electrical system. Seriously!
The fuse holder MUST be within 18" of the battery.
Be sure the fuse holder is connected solidly to the power wire.
Be sure you have the right sized fuse!
Be sure the fuse holder is mounted in a safe place, and the power wires are all secured away from any moving parts.
8.) Hook up any special battery terminals
If you have any fancy-schmancy battery terminals, now is the time to be sure they're connected properly. Be sure they are secure and protected. Hook up any other of your vehicle's cables to the battery. If you can get covers for your new battery terminals, I would recommend them.
9.) Reconnect the battery.
Put your shiny new terminals on those battery posts!
10.) Test!
Before turning your system on, turn the amplifier gains all the way down. Turn on your system and listen. Does everything work? How much noise do you hear? Is there audible distortion (If so, don't listen for long!) If everything's square, move on to the next step!
11.) Permanately Mount your amplifier
I hope that before you have gone through the previous nine steps, you have thought about how your amp fits into your system, and how you plan to install it. If not, I BEG OF YOU to think about this first. Figure out where you want your amp, how you'll get power to it, and what (if any) components will be installed near it. Also, don't be a fool! Be sure you've budgeted so you can actually afford everything you need for your amp to be installed FLAWLESSLY. Taking just a small amount of time to think about this stuff will pay off for a smooth install, and great sound. If you don't plan, you will screw it up.
When you mount your amp, you'll want to be sure you are protecting it from any sort of physical damage and heat. Car amps are tough, but you need to be sure that you are installing it in a way that protects your amp from these hazards.
Soooooo, to protect your amp from physical damage (because they are usually installed in places where they are prone to damage such as in the trunk or under the seats), it is best to build some sort of enclosure for it. This enclosure should be big enough to contain the amp (and possibly some fans), as well as the appropriate wiring. You will also want to be able to easily access the controls. If you really like to tweak your system, you might want to make your amp rack easily removable, but also keep theft in mind. Be creative on how to protect it. The truth is, you can get really fancy here, or just do something quick. Both will work.
Another thing to keep in mind when building an enclosure for an amp or mounting the amp in a place that is hot or has poor airflow is that the amp will get HOT. Heat damages electronics, so you should figure out a way to keep your amp cool and happy. Use fans, or even redirect the air conditioner!
One last thing about amps: I have found that if your amp is mounted to metal, it is sometimes prone to noise. I recommend mounting your amp to a piece of wood before installing it. This will prevent any sort or weird ground loop effects that introduce noise to your music.
12.) Tweak!
Now that you've installed your amp(s), you're pretty excited to get rollin. Step 1: Be sure all of the amp's gains are down, the bass boost is off, and the crossovers are set to the correct frequency band.
Get one of your favorite CDs, preferably one that is clean sounding. I have found classical and jazz to work great, but alternative and pop work as well. Try to avoid really loud or bass heavy music. If you must, try to use a more melodic CD: Not one that's just all bass, or noise, you know? The important thing is that the CD is representative of what you normally listen to, because it's YOUR system, and it's YOUR music. Darn tootin!
Step 2: Power on!
Step 3: Turn your head units controls to neutral. EQs off, loudness off, fade and balance centered.
Step 4: Turn the volume up until you hear distortion (you know it when you hear it, and go on to step 5), or the volume control is all the way up. (go to step 6)
Step 5: If you hear distortion, back the volume up until no more distortion is heard. At this point, you know how loud your system is gonna go before it starts distorting, sounding horrible, and smoking speakers. (Move on to step 7, and lower your volume!)
Step 6: If your head unit goes all the way up, and doesn't distort, you have a good unit that your amp can handle. Go to your amp, and while the music is playing, slowly turn up the gains. Once you hear distortion, back off a little. Turn your head unit's volume down!
Step 7: Now go to your head unit. Set all of the eq, loudness, crossover controls, and dsp that you want. Repeat steps 4-6 with all of these controls set to how you want them.
Step 8: Set all of your amp's bass boost or other controls to how you want them. Repeat steps 4-6 again.
Step 9: Once everything sounds good, you're ready to put a cover on your amp enclosure, and be sure your fans are hooked up properly. Put it away and forget it!
Step 10: You're in business! Have fun, and don't wake up your neighbors!
good luck to a long time to write dont for get to rate my help
  • 12 Answers
SOURCE: I have a Pioneer GM H22 amp. Powers up nice, fan
On Pioneer, Green wires are left spkrs, Grey is right spkrs solid is positive black stripe is neg.
Posted on Jul 07, 2009
Finding Automobile Repair Manuals Online
Many of our patrons are interested in saving money by
repairing their cars themselves. They know from experience
that repair manuals and diagrams can make their work a lot
easier. When their local library doesn't have the manual they
need, they decide to see if they can save a little more money
by finding a free copy of the manual or diagram on the
Internet.
Unfortunately, these materials are almost NEVER available on
the Internet for free! The reason for this is that the people
who publish the manuals and own the copyright aren't about to
give the material away free--they want to get paid for their
work!! Also, many of the manuals are so large, it would be
very costly to place them online and store all the Web pages
or provide access to them from a database.
The Internet, though, has a large number of web sites where
you can buy service manuals and schematics from bookstores,
publishers, and other collectors. Here is just a sampling of
what sites are out there:
Chilton Repair Manuals
http://www.chilton.cengage.com/
Factory Automanuals
http://www.factoryautomanuals.com/
web based auto repair manuals
Haynes Publishing
http://www.haynes.com/
Vintage Books
http://www.vintage-books.com/
AutoLit.com
http://www.autolit.com/home.htm
RepairManual.com
http://www.repairmanual.com/ Repair Manuals Online http://www.autolit.com/home.htm Vintage books com Rare used and out of print books Haynes is the information resource for the DIY enthusiast Factory Auto Manuals is specialist dealer in quality used factory car...
Jan 30, 2014 | Pioneer GM-X924 Car Audio Amplifier
Amp 2400 watt sub woofer
Use this link and print it up and take it to a local car stereo shop to get ideas, then shop for it the way you want .http://reviews.cnet.com/car-amplifiers/pioneer-gm-x924-car/4505-6726_7-30233385.html
Their not bad amps but don't exspect a lot.
Sep 24, 2013 | Pioneer GM-X924 Car Audio Amplifier
I have a pioneer gmx962 mosfet amp, just lost power, checked all the wiring, fuses...all seems ok....???
if the main fuse under the hood is a glass fuse try to replace anyway. The glass fuses usually look good but the connection on the ends of the fuse where you can see become bad
Jun 15, 2010 | Pioneer GM-X962 Car Audio Amplifier
I have a Pioneer GM-X862 when i have it
make sure you do not have the ground and power crossed or touching if that dont work then you have ground problems hope that helps if not your amp is at fault(replace it)
Nov 03, 2009 | Pioneer GM-X862 Car Audio Amplifier
Hi i have 760w pioneer that i am selling but i dont think it works because the red light does not come on when the wires are connected..are they're special wires that should be used for it to be connected?...
IF THE WIRING WAS RIGHT, THOUGH THE WIRE SIZE HE USE TO CHECK WAS NOT PERFACT, IT SHOULD HAD COME ON FOR ATLIST AS TESTING RESULT, CHECK THE WIRING AGAIN, AND FUSE..HOPE IT WORKS
Oct 13, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Aug 28, 2008 | Pioneer GM-X924 Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-X924 Car Audio Amplifier Logo
253 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
