Question about Eureka Vacuums
I replaced the belt in our Eureka Boss Smart Vac, it still seems loose, it uses a type R belt. The beater belt still doesn't seem to turn properly and seems that it doesn't pick up very well when I use it on my berber carpet. We have 2 dogs and I like to use it frequently. I have changed the bags and belt......
  • 377 Answers
Check to see that the beater brush is not frozen up. Pull the brush and clean it, spraying some WD40 on each end piece that holds the brush in place. Also be sure the belt is properly installed so that the brush turns in the correct direction. If the brush is not turning or not turning in the correct direction, it will not beat the dirt from the carpet so that it can be picked up by the vacuum's suction.
Posted on Oct 01, 2010
Eureka R4870P belt keeps breaking
There is likely something restricting it from turning freely. Check the endcaps to see if may have dust and hair wrapped around them
Aug 02, 2014 | Eureka Boss SMART VAC Upright Vacuum,...
Screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
Belt seems to have broken where do I get new belt for my eureka
If this is the same model as the one you have dont forget the 402A has a brush roll on/off function located on the main power switch so that it can be used with the beater bar on or off. If you remove the sole plate you'll find a toothed drive belt. These don't normally break and can be difficult to find a replacement. Check EBAY or Electrolux/Boss for replacements. It may just have slipped off its mechanism.
Jun 16, 2009 | Eureka 402A Bagless Upright Vacuum
Can't figure out how to get the belt around vacuum motor shaft
I am assuming you are referring to the beater bar belt. You will either find a release lever on each side or a small screw and bar restraining the bearing that holds the bar in place. Removing whichever of these you find will allow you to install the new belt. Clean up the dirt accumulation on the bearings while it is apart.
Dec 31, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka The Boss Smart Vac, beater bar stops turning when you use it on carpet
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Oct 24, 2008 | Eureka Vacuums
Vacuums Logo
291 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
