Question about Canon Office Equipment & Supplies
WHENEVER I SCAN A DOCUMENT INTO PDF IT DOES NOT HAPPEN
When my ptinter all-in-one CanonMP150 didn't scan well I added "VueScan" and Gutenprint and the problem went away.
Posted on Oct 01, 2010
Scanner Model is Kodak i4200. Whenever I scan a document in Color Mode the background is filled with BLUE color. This doesn't happen when I scan in B/W mode. Can you please help ?
If you are talking about a blue tinge Try turning on background smoothing in the driver under adjustments that may sort it or adjust the brigtness and contrast a little if that doesnt solve it Image calibration is the next step you will need to contact Kodak as its not a user function
Jan 09, 2015 | Kodak i4200 - document scanner
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
When i email scanned docs from my HP officejet 8500 Plus printer to my email, the pdf's are too large. how do i set them to be emailed at a smaller size.
No problem, you can solve this problem very easily :
Whenever you scan a document directly to your e-mail in a PDF format then printer scans it using its own property and only scans the document without any editing in the font or characters.
But the output i.e. the scanned document in pdf shows the same text using its own properties. That font is selected by pdf and not by the hp software.You can open the scanned pdf file and manually change the font size.
Or else
The best way that I will suggest you :
- First scan the documetn in a pdf file or any format on your computer instead of directly on e-mail.
Because when you scan it to your computer printer will scan the document directly to computer and in this way after scanning you can open and see the document. You can make sure if it is scanned properly or not, however when you scan it to e-mail there are chances when we dont verify if the document is scanned properly or not. If there is any hardware issue or any other error then it will scan half page or a blank page....we wont be able to verify it.
- Also if it is an official document which is half scanned or has some problem in it will give a bad impact on the receiver which is not good for professionals.
- By scanning on computer you can verify the document, can make required changes and will be able to send the document in a proper way. It is going to take few seconds but results will be fruitful....try it..!!! I do the same way and there is not much difference
Feb 26, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I AM NOT ABLE TO SCAN DIRECTLY TO PDF FROM MY HP 4255 ALL IN ONE PRINTER
Scan directly using Adobe software from computer
  • 1 Position the first page of your document on the flatbed scanner and close the lid.
  • 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
  • 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
  • 4 Click "Scan."
  • 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
  • 6 Repeat the above steps as necessary to scan a multi-page document.
    Read more: How to Scan a Document into a PDF ' eHow.com http://www.ehow.com/how_4895483_scan-document-pdf.html#ixzz18vbeLoUI
  • Dec 23, 2010 | HP OfficeJet 4255 All-In-One InkJet...
    Can I scan a document to PDF?
    any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
    Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
    Need to email documents in pdf format
    Just scan or create the documents and save them as pdf files. Start your email & make them attachments.
    Oct 29, 2009 | Dell 926 All-In-One InkJet Printer
    How do I scan a document into a pdf and send by email
    hi,
    HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.hp.com/printer/prob676ijt65/solution
    astrtr21
    Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
    I have a HP Photosmart 6180 series printer. I want to know how to scan multiple document of several pages or more and put into one file? Whenever I have scanned in the past, I have only been able to put 1...
    To scan documents, you must choose the PDF scan. Need to figure out how to choose to scan as a PDF. That's in the software or scan buttons. In that setting, there should be a choice of single or multiple scans. After the scans, you choose finish and the program should show you a PDF document and then save to a folder of your choice.
    Jul 30, 2009 | Epson Printer
    Black line on document when I scan from platen or ADF or scan to save as PDF.
    As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
    For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
    the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
    You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
    Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Scanning document
    i had the same thing happen to me i went threw every thing and cleaned and still was there i came to realize that it wasnt the scanner but the software pdf that was being used the seriously took me by surprise so i went out and installed a fresh copy of pdf writer this resolved my problem with the pink markings
    i hope this was of some use
    Apr 24, 2008 | Fujitsu fi-5120C
    67 people viewed this question
    old marine
    old marine
