Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Green screen people
Please help, I need to know if there is anything you can do to help?
I tried to connect the rca cable to a different input and it did'nt help... My e-mail is oligage@yahoo.com...
Thanks
Marcus
  • 2,326 Answers
Try to unplug the TV for about 30 minutes.
That should reset the circuity and hopefully it might work again. If that did not work, I would say the color wheel might be defective.
Posted on May 26, 2008
  • Jaime Hernandez May 26, 2008
    Check the color settings in the Video menu. Make sure the tint control is in the middle of the bar as well.
    Sergeant:
    Champion:
  • 347 Answers
Hi Oligage,
If you want to check out the user manual.
Here it is:
http://www.fixya.com/support/p169140-zenith_e44w46lcd_44_in_rear_projection/manual-6442
  • Santiago Vallejo
    Santiago Vallejo May 26, 2008
    One quick solution you might try, is to check out how high is your brightness. Try to lower it and see if the amount of green reduces.
    Try to check that the contrast, brightness, and other menu options are not messed up.
    Let me know if this Did/didnt worked
    Brigadier General:
  • 3,614 Answers
may i know on what unit you want to connect the rca cable, knidly be specific on the info given
~micro
My flat screen samsung is green
HI, Green screens are almost always caused by no signal-so check the input connections: rca cable, screw on coax connector, make sure channel is right 3 or 4 for a vcr type connection, sometimes channel 60 for some types of satellites-new rca cable for other connection-can determine if the cables are good by connecting to known working equipment , and make sure the plugs on back of television aren't loose-they've been known to come loose inside from the circuit boards before. Hope this has been of use, good luck Prodzilla
Mar 31, 2011 | Samsung Televison & Video
Turned on the tv and i have no picture just sound...
Most likely fault is the backlight inverter board. May be a simple fix due to bad capacitors or may require a new inverter board.
You can check that the LCD screen is still working by shining a torch on the screen and looking carefully for a dim picture. Try putting the menu on so that you have a known static image to look for.
Feb 11, 2011 | Sanyo DP46849 46 in. HDTV
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
When I turn on my Wii the led light is green, but the screen in black and I can hear the sound.
make sure the video cable is plugged into the correct input and that there is no cuts or crimps in the video cable. Also try a different video input. As sometimes a tv will have s-video input and a rca input and if you dont have it in the selected video input it might not display.
but because you have audio i am confident that your problem lies in the video input not being properly plugged in/selected or the cable is bad.
So try a input that you know works and turn off the wii then unplug the video/audio cable from the wii and plug it back in.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Nintendo Wii Console
Connecting wire between pc to tv
Depending on what type of TV you have, connecting your PC to your TV shouldn't be very expensive. Most newer models of TVs come with a VGA input.
Your computer has a cable to go to the computer screen, this cable is known a s a VGA cable, it looks like this:
Your TV might have a VGA input which looks like this:
All you have to do is unplug your VGA cable from your computer screen and plug it in to your TV so your cable will go fro your computer to your TV instead of your computer to your screen.
If your TV doesn't have a VGA input, it will have an RCA input which looks like this:
You can buy a VGA to RCA cable which will allow you to connect your computer to your TV which looks like this:
You can buy a VGA cable here:Click Here
You can buy a VGA to RCA cable here: Click Here
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Feb 19, 2010 | LG 22LH20 LCD TV
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
New setup
do you get anything on screen, like the menu or channel number?
Feb 05, 2008 | RCA L42WD250 42 in. LCD HDTV
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
