Question about Sony Cyber-Shot DSC-S40 Digital Camera
Hello there, my camera does not work the screen says USB Mode Connecting and sits idle :( Please help me fix this .
  • kakima Oct 01, 2010
    Have you considered NOT connecting the camera to the computer?
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Having gone over five months without a response, I assume my suggestion to use a card reader solved the problem.
Posted on Mar 28, 2011
When I switch on my camera (sony rx100) the screen says usb mode connecting even though there is no usb cable attached. The message stays on the screen and the camera cannot be be used to take a pictu
if you can get to the menu on the camera see if there is an operations menu that says to disconnect the usb or to close the usb. It might just be on and not closed.
Apr 11, 2014 | Sony Cyber-shot DSC-RX100 Digital Camera...
Hi, I can not tranfer images from camera to computer using a usb cord. I tried 2 different cords and 4 different computers. I do not have a card reader, so please don't ask me to go purchase a card...
Emily,
We need to rule some things out. Do the USB cables you're trying to use work on other "known to be good" devices? Do not reuse any cable(s) that doesn't work, even if new. Once you have a cable that has been proven to work, try connecting the camera to the USB port on the computer again. Make sure the camera power is OFF while connecting to the computer. Only after connecting should you turn camera power ON again. You can review the whole process starting on page 147 of the manual.
If it doesn't work, it is possible that the ports you're trying to use is either 1) defective or 2) overloaded. Try connecting to a different USB port on one of the computers. If you don't have another USB port, or if it still doesn't work as expected, remove all the devices connected to the USB ports that are not needed to operate the computer. This will lower the amount of power the computer needs to supply to USB devices (some - but not all - computers will flash a message on the screen if there's too many devices connected). Reconnect the powered off camera and try again after turning back on..
If you're still having a problem, suspicion turns to the camera's USB port. Resolving a problem within the camera will likely be the most expensive fix. It took considerable restraint, but I didn't even mention the other solution ;-)
I hope this helps & good luck! Please rate my reply - thanks.
Feb 11, 2011 | Canon EOS Rebel XSi Digital Camera
When i connect the camera to the pc (have already selceted pc as the usb mode) the camera says ''connecting to pc'' but never actually connects. how do i fix this...have read manuals and no joy! please...
Hello. This method has worked for me in the past. Turn off PC, make all connections , turn on camera and restart computer. If this works your done.If not and your using Windows open cotroll panel and then using the classic view open Add Hardware try using the wizard to find your camer
builderdale
Jan 17, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
Black screen HELP!!!!!!
Try this,
Before plugging into USB cord go into menu on the camera. Then scroll down to setup press, then scroll down to USB mode. Press OKAY, then click on PTP and OKAY button. Now exit out by pressing menu button until back to the LIVE CAMERA phase.
Now plug in USB, CONNECT TO COMPUTER & should read PROCESSING...
Wait a few minutes (camera is very slow). Watch computer screen as a small bos should pop up which reads
AUTO PLAY now scroll down to
DEVICE OPTIONS - IMPORT PICTURES USING WINDOWS
Click on this
Now photo's should start downloading
Sep 27, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sony Handicam DCR-HC40E not getting recognised by Vista
Hello
I found a solution installing the generic Sony USB driver in Vista Ultimate using compatibility mode (Windows XP SP2).
Mar 12, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
USB Not working =S
Possibly, the cam is in webcam mode or other mode beside camera mode. I have an older sony and there is a mode that doesnt seem to work for me too. Im not next to it so I cant tell you what it is, but look into the setup screen and make sure the camera is in USB mode.
Mar 04, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Is the problem occuring in the USB, Memory Card or the Camera?
hello, i have the same camera, the LCD is not bright i can barely see the LCD, any of you have any idea how to fix it wihtout having to send it back to warranty? i checked al the settings and they are right the LCD should be working well.
i will really appreciate your help.
Dec 26, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Connecting digital camera to pc
Hello i have Benq DC C640 camera
and when i try to take photo it sayes card lock, even when i changed the simcard it still sayes the same problem . Help please
Oct 03, 2007 | Cameras
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
