Where is the ethernet connection on the back panel of my HP Pavilion 4700?
  • 32,281 Answers
It may be on the Left or Right side of the laptop.
Posted on Oct 01, 2010
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
How do you connect the hp pavilion ze4600 with Ethernet cable
The ethernet (LAN) port is on the back right corner next to the USB plugs. From the far right, the plugs are as follows: power plug, USB, then LAN. Plug the ethernet cable into this port.
Sep 20, 2012 | Computers & Internet
I can't get the onboard network connection to work. Wireless works fine. When I look at properties it says that it is connected.
The Ethernet jack might have a broken wire inside the laptop. Try a modem that uses a USB connection instead of Ethernet - if it works, then the Ethernet jack has an open wire.
Nov 11, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
CAN´T CONNECT TO THE INTERNET BY THE ETHERNET CONECTOR
Sorry for taking ages, for some reason i didn't get a notification about your comment. Anyways, if it's giving you an I.P through wireless, try going into your Ethernet adapter's Properties (Control Panel -> Network connections -> Right Click your adapter and select Properties -> Internet Protocol (TCP/IP) And see if there is already an I.P there, if there is, select "Obtain I.P Address Automatically"
Nov 07, 2009 | HP Pavilion DV6745US Notebook
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
CAN'T CONNECT TO ISP USING ETHERNET NETWORK PORT DIMENSION 4700
make sure the cable is in the correct place. (8 ping plug-little bigger that the phone plug.)
1). start>>control panel>>system>device manager.
make sure there is not "red X" or yellow!" ont he network card.
if that is OK. right click on "my network place" on the desktop>>local area connection>> right click on properties again.
you will see the network card name, and select TCP/IP under the " This connection use the following item" box. Click on properties.
make sure the " Obtain the IP address automatically and the "Obtain DNS address automatically" are check.
shunt down the computer
wait 2 minutes, restart the machine.
open the Internet Browser after the machine finished loading.
Dec 16, 2008 | Dell Dimension 4700 PC Desktop
HP Pavillion dv2000 is not detecting the network cable for lan
ok...so...unhook the cable completely
go to control panel
device manager
and see if the ethernet device is clear or has some mark on it..you may need to remove that or disable it, then re install
Nov 21, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
