Model no. 43PP925.
Is it that there is dry solder an all the pcbs?
  • 121 Answers
Check the solder only around the flyback area because that could make a set work off and on
Posted on May 26, 2008
What are the uses and benefits of wave soldering machines?
While assembling a large printed circuit boards, one aspect to invest in is a wave soldering machine. As the process requires the soldering of multiple PCBs at once, using a wave soldering machine is a good decision to improve time keeping and reliability.
Indian market has seen a definite upswing in the demand for wave soldering machines. This is because the trend of soldering processes has caught on in the industry and the high demand is met with an enthusiastic supply at very affordable prices.
Benefits of Using a Wave Soldering Machine are Listed below
  • It is time friendly and allows for the soldering of multiple PCBs effectively during the assembly process.
  • It is more productive in terms of soldering quantity as it covers multiple joints at once.
  • It improves accuracy in the soldering process as temperature can be easily regulated to maintain a healthy flow of the solder.
  • It is easily accessible as the Indian market offers very reasonable prices and quick delivery for any soldering products that need to be purchased.
  • Finally, industries using wave soldering units have a competitive advantage both in terms of accuracy as well as productivity in terms of quantity and quality through the soldering process, if a wave soldering machine is used.
Jun 13, 2016 | Welding Tools
Phillips 43pp925 won't come on but relay clicks
You can download the manual from here, hope this helps.
http://www.nodevice.com/user_manual/philips/tv_projection1/43pp92579.html
Dec 23, 2013 | Philips Televison & Video
Manual Needed for Philips 43
you should be able to locate one by sending a request to customerservice@tvrepairworld.com they have most user and service manuals available for most models.
Jun 19, 2012 | Televison & Video
When i try to turn on the tv it wont come on and then if i leave it a while it will turn on and work fine so i took it off the wall and gave it a clean and now it wont come on at all it is a LG plasma tv
Sounds like either a loose connection suspected from the fault worsening when you moved it, or a dry solder joint on one of the pcbs. It could also be a dry capacitor on the power supply board shown by bulging tops on the capacitor. It could be that when mounted on the wall, the tv was located near a source of heat and this heat helped the low value capacitors to warm up and work. Either way it will be one of these 3 possible solutions.
Feb 13, 2010 | LG 50PG20 50 in. Plasma HDTV
My paeveybandit 112 is buzing when i turn it up
Check the power supply area for bad connections especially near the large capacitors. If one or more of those are disconnected, the DC voltage will have some noisy AC on it that will sound like a buzz.
Keep us posted.
Dan
May 15, 2009 | Washburn Amplifiers: 25 WATT Guitar...
Philips 109 cm rear projection TV model 43pp925
try unplugging the circuit board thats connected to the green picture tube thats the board in the middle then while the boards unplugged try to power up the tv if it works it means your green picture tube is shorted
May 25, 2008 | Televison & Video
Philips 43PP925 rear view television
Can you describe what you mean by "funny with colour" please? That will help to determine the problem circuit.
Thanks,
Dan
May 23, 2008 | Philips 43P8341 43" Rear Projection...
Bad solder connections on the vertical ic
Cold solder is normally fix with re-application of heat using a soldering iron. This is a fairly straight forward job and should not be that difficult. Probably what would take more time is opening the back cover and exposing the solder side of the PCB. Most TV PCBs are slide in/out (it may held in place by screws or retaining clips or side locks. Additionally, some of the wires/connectors may restrict movement and therefore must be disconnected temporarily).
Good luck and kind regards.
Dec 08, 2007 | Zenith B25A02Z TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
