Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon MP160 Paper jam error E3
OK as I discribed above, printer tries to feed a sheet in, the sheet stops and wont continue.
The LED says this is a E3 error, meaning jammed paper.
Only thing is, there is nothing in the parth of the paper feed guide to create a paper jam up.
I have taken my printer apart, twice now, and unless the fault it is invisible (which it wont be), I just cannot see any phisically reason for this failure.
Pressing the <|> green button, now alows the paper to proceed all the way through the printer, and spits it out, thus proveing there is nothing to make a blockage.
OK, I have seen a small vertical flat black leaver mounted on the vertical steel back close to the inch grey paper roller wheel. It breakes a LED switch light parth, if this was open circuit, or not moving, could it give a E3 jam error?
If the soldered connections on this small PCB were dodgy, resoldering them could restore functionality.
If the white plastic vacuum ink ****** was jammed, internally, could it load up the DC motor, and the circuit sence a current overload and shut down the drive motor?
OK what should I do in your opinion (in ordered logical steps) to eliminate this fault.
Curious
  • 2 more comments
  • Lisa Imberi Dec 29, 2008
    I have the same problem--sort of. Except mine won't do anything at all. I can't get the rollers to move to push a sheet of paper through. I can see that there is not one stuck, at least it doesn't appear that there is. I don't know what to do.
  • gooyong_shin Feb 21, 2009
    I have the same symptoms and problem. But the paper would not go in. I do not know where and how to look for the jammed paper.
    Please help.
  • gooyong_shin Mar 01, 2009
    The message says: Paper jammed. Error E3. But nothing I can see is jammed. The does not feed.
  • nezu_chuuko Apr 12, 2009
    The paper will feed in about 1/2 inch then jam. The green button feeds the paper through, then the next page jams again. Very irritating >:(
  • 12 Answers
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
  • 2 more comments
  • Gemma Payne
    Gemma Payne Nov 24, 2010
    I keep seeing your post - but I have no idea where to start?
    I desperately need my printer! it's the mp170 one.
  • banfixa Nov 24, 2010
    Hi gemzee. My MP160 is still going fine and the E3 error has never returned, so the fix I posted has proved to be a long term solution. All it needed was some lubrication in the critical areas. Unfortunately I only got to the bottom of the problem by dismantling of the whole thing, applying some lube and putting it back together again. What I don't know for certain is whether you can apply some lube and fix the problem without taking it apart. Here's something you could try. Open the top with the power on and you will see the ink cartridges move to the left. You should be able to see the edge of a length of steel channel that the cartridges travel along when they move back and forth left and right. Apply a drop of light oil to the channel edge and smear it along the length of the channel both on the outside facing edge and the inside facing edge. You may need to apply the oil first to a cotton bud and then transfer it to the channel. Close the top and see if that solves the problem.
    If it doesn't, open the top again and look for the small white plastic tongue that sits just above and behind the channel edge at the right hand end. That tongue is struck by the cartridge carrier when it moves all the way to the right. Apply a bit of lube to this as well. I hope this helps.
  • joshmo99 Aug 30, 2011
    lubricating the tracks worked like a charm for me
    also, i didn't have to take my printer apart
  • 3 Answers
Is not paper jam ( E 3 3 ) but is something related with this ( just E 3). That means something is stock, is blocked inside on the paper way. Can be a piece of paper or a leaf in my case, and that is pushing a sensor. This sensor ( his arm ) can be reached when you open the top of the printer and there you can see a white long printer spare part. The mechanical sensor is placed in the right window of the white printer spare part between first two springs. So E 3 means is something there and you have to remove. It is a tight place. Insert a thick paper and force to insert instead of paper. You have to rotate the big wheel placed in the left side of printer
Posted on Dec 21, 2009
  • 29 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-13
Posted on Sep 04, 2009
I was sooooooooo frustrated and did 1-2 hours of research for fixing the MP160 cannon printer ..... my paper was also not feeding, I oiled the tracks and still nothing worked, then I read that if you feed a thick paper like a greeting card (thinker than a piece of paper) and feed it while you press the green ,<I> button then try to force the card through and one of your kids toys will appear --- after about 5-8 times (do not give up) I got my sons lego ..... then the printer worked after twice trying to print - again do not give up - this solved my E3 problem ----- 2-3 hours of research and work on the printer..... I almost pulled something of importance with tweezers (looked like sticky tape - gaffer tape...) but this was not the problem -- i pushed it back in and it seems ok .....good luck .....
Posted on Jun 21, 2012
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
Posted on May 28, 2008
The long term solution is to start looking for a better printer, and you might want to forget about this brand, EVER! I've had enough of it after having to put up with it in the office for the past 10 years, because the previous management thought it was cheaper, failing to calculate the lost hours, workers' frustration and low productivity. I am using HP now (both office and home), and am a happier end-user than before; meanwhile, you can try all the methods above, but the problems will keep coming back every now and then, because I think Canon try to sell too many things, thus, the firm ended up like "master of none". I had a Canon camera which had a circuit problem, a printer with a paper-feed problem and a copier which required frequent maintenance. I dumped them all in the garage.
Posted on Apr 24, 2010
I just dealt with this today and I unplugged the USB from the computer and then plugged it back in and now it's magically working. ?!!
Posted on Jan 20, 2013
The paper jam occurs due to a white gear located at the bottom right of the printer. you need to disassemble it and either replace or repair the gear. the gear can be identified as a set or 2 gears attached together by a spring wch allows only one side rotation of the gears. you can see a piece of thin metal rod attached on the side of the gear holder. for repair purposes, take that outand make it as straight as possible and fix the rod again. then disjoin the gear with spring in between and increase the temper of the joining lock on one of the gears by stretching it outside a little bit. make sure it wont break. then fix it again and i can ASSURE you that the printer no longer shows the error. :) try ;;)
Posted on Mar 24, 2010
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MP160 E3 paper jam error, when it's not really a paper jam. Help!
Small pieces of debris can stop your printer in its tracks.
Take a flashlight and look to see if you can find anything and then remove it.
Get "canned air" at any computer or office supply store and blow out everything you can in the printer. You may be amazed at what comes out.
Nov 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper and displays error code E3... have tried cleaning the feed mechanism as per the owners manual but problem persists
hi,
tokl-20
Aug 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 flashes when turned on
hi,
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 with E3 Flashing.
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Wont fire up, just reads E3
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Nov 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E3 code error mssg on printer MP160
As you will probably know E 3 on Pixma is paper jam.
Double check that there is no paper inside, and turn printer upside down shaking it a bit to check if there is any small foreign object (screws, pins, coins etc.) stuck inside.
When there is no jam in the paper path, this problem is typically caused by a broken part in the paper feed mechanism, in the page unit.
The paper feeding mechanism has two white plastic gears connected together with a central spring, near to the waste ink tank, at the bottom of the printer.
This are quite delicate, they often get stuck or boken, or you lose the spring, and the printer stays stuck with E3 error.
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160,error code e3
hi,
587
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
15,470 people viewed this question
old marine
old marine
