Question about Simpson PS2600 PowerShot Commercial-Duty Gas Powered Pressure Washer
5.0 Hp Honda motor for pressure washer . Will not start. pops threw carb. seems to have back pressure, without waterpump attatched.
Honda 20 HP will not start
Normally there is a whole series of questions as to it's last use, storage, and any specific's of "not starting that you are experiencing.
Assuming that it is turning over adequately by electric start, I would suggest that you look at the plugs. If they are dry, then you have a problem with fuel delivery. Spraying starting fluid into the carb intake should get a pop and a few turns out of the motor. If not, you likely have a spark or compression problem. Check for proper oil fill level. These motors won't start when low on oil. Each possibility has a long chain of test and repair procedures. If you can chase down a liikely cause I may be able to help you further.
Oct 29, 2012 | Honda 20 HP Engine - GX630RQXF6
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
My gc160 pressure washer will start with a 'gunk' spray but dies right away.
it is not getting fuel.check if carb is getting fuel from tank, by removing hose at carb. make sure airfilter is clean ascarb cannot vacuuum in fuel if its dirty, try staritng without filter on.if all that is good, you will need to remove bowl from carb, may be dirty
Aug 09, 2009 | Honda 8 HP Engine
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
May 29, 2009 | Honda Pressure Washer PSI 3000
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Simpson PS2600 PowerShot Commercial-Duty Gas Powered Pressure Washer Logo
74 people viewed this question
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
Tim Venetis
Are you a Simpson Garden Expert? Answer questions, earn points and help others
