Question about LG Ovens
LG MH3948W microwave showing E-10 error - LG Ovens
Kitchenaid superb microwave.oven combo KEMC308KSS0 is giving F2 E0/E1 error. Replaced the switch membrane and also the Control board. The error still shows up.
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Apr 15, 2017 | KitchenAid Ovens
Error E7 : F1 GMC275PDs07. Microwave works normally but will not heat. Magnetron changed out and still will not heat.
If your microwave is a 220 then reset the breaker by turning it off for 10 seconds and then back on. Then check it. Since you replaced the magnetron, the signal to the mag is interrupted. Did you replace the control panel? If so, then look to see if it is wired back in order. Does the fan operate when you open and close door? If not, then check door switch.
Feb 24, 2013 | Whirlpool GMC275PD Electric Double Oven
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
Microwave tray does not turn therefore microwave does not heat. When it turns it heats properly.
Hola Carlos,
See below a tutorial that shows how to diagnose a microwave:
http://www.desmontalo.com/index.php/como-se-desmonta-un-microondas-lg/
May 11, 2012 | GE JKP85 Electric Double Oven
Keypad error
Most likely a Stuck keypad. Got a Brand and Model number so we can see your unit as you do and offer more assistance?
Waiting to hear from you,Eric and Ann Campion
Apr 19, 2012 | Ovens
What can i do please tell me i cant start the micro wave oven it show E-10 .& I DONT START IT
Sounds like you have a bad control, try unplugging the microwave for one min and plugging it back in. if this does not clear the error code the board will need to be replaced, we can walk you through the necessary steps.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Ovens
LG MICROWAVE OVEN PROBLEM MICROWAVE Oven is not functioning. though it seems running.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 03, 2011 | Ovens
LG Microwave oven: start button not working pls guide
Microwave Oven Basic Troubleshooting Tips
heatman101
z
Sep 30, 2010 | LG Ovens
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Ovens Logo
138 people viewed this question
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
