Question about Acer Aspire 5315 Notebook
Blue screen error/bios is disabled. What would be the problem??
    President:
  • 2,291 Answers
Check the size of Random Access Memory (RAM) in your computer. Its small size could be the reason for this problem as many of today's software need large amount of memory to operate in smooth manner. Additional RAM will also increase the efficiency of your computing particularly for gaming.
• Excessive use of computer or a malfunctioning cooling system can make computer/laptop overheated. Whenever system is heated, its efficiency will go down. BSOD is one possible consequence of over heated system. Keep fan of your computer in fully functional mode.
• Registry is the most vital part of Win 7. Corrupt registry is the biggest reason for BSOD in Win 7. One way is to clean registry manually but manual tricks could wreck your system completely if you are not a top notch computer expert. More appropriate way is to buy a good registry cleaner reg ion out and PC optimizer
Posted on Oct 04, 2010
How can I reset bios password on asus notebook ?
bios password reset methods depend on model & how its designed,
in laptops cmos battery reset will not remove bios password.
you can reset bios passwords by:
1. Entering master password, if it shows password disabled with Error CODE after failed attemps,
2. shorting bios reset jumper located anywhere near the ram slots in motherboard
3. Re flashing the Bios Chip
Jun 21, 2014 | Dell Inspiron 1000 Notebook
Blue screen disable bios memory options
- Disconnect incompatible hardware
- Check and repair disk errors
- Perform System Clean-Up
- Fix Windows hidden errors with Reginout.
- Scan for Malicious Content
- Run System File Check Up
Good Luck :-)
Feb 06, 2014 | Dell LATITUDE Computers & Internet
My computer keeps going to the blue screen showing the message 0x0000001e,oxffffffc05,0xfffff80003dcd7da,0x000000000000000001, 0x0000000000000018, bios update, disable bio memory such as caching or...
Maybe you can try the following solution... Blue screens are typically caused by software errors in device drivers: in Windows systems by poorly written device drive , They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. They can make our computer run into blue screen error and prevent us from working, studying or playing games online. Now, let's learn to fix blue screen error as follow steps together. You will find how easy it is to solve the problem.
Step 1.Burn a bootable CD/USB by Fix Genius for fixing blue screen error.
Step2.Change BIOS of the computer to boot from CDROM or USB Device Drive.
Step3.Fix blue screen of death with the created CD or USB easily.
Computer blue screen exists in kinds of windows system, and the solution is available for windows 7 blue screen, xp blue screen, vista blue screen and even windows 8 blue screen, etc. Laptop blue screen seems more likely to occur as its insufficient configurations. But it isn't real and if we can keep using our computer in a good way, they can both be health. After,blue screen of death is no longer a horrible disaster when it occurs to us, just use the methods above and we can solve the problem soon.
Nov 10, 2012 | LG AKB72915206 REMOTE CONTROL
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
My computer wont load windows at all says it shutdown so it wont harm my computer what do i do
go to disable automatic restart on system failure and check whether it gives some blue screen error?
go to bios and do a default on bios by pressing alt+e ,alt+d & alt+f
now disable floppy drive,cd drive,sound and network then exit the BIOS by saving the changes.
now reboot the system and check.
alos make sure that USB emulation option is set to no boot
Dec 26, 2010 | Dell Dimension 2400 PC Desktop
When i turn on the laptop there are a blue screen and that is the text - there are a problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT...
did you install any new hardware like a card, usb product, please have them removed, also if you enabled any stuff on the BIOS setup please go back and disable now, let me know what the situation is,
regards
Apr 21, 2010 | Computers & Internet
Blue screen on start up and no response
go in bios and disable the on boot password and if tha blue screen appear again write down the error that is writen on that page and search on the net for it.
Nov 28, 2009 | HP Elitebook 8530w Mobile Notebook
Operating sysmtem not found. Cannot re-install either. Blue screen saying to disable shadowing and cacheing in BIOS!!! Cannot access F8. Installed new hard drive and the same message.
If you have a new hard drive,it must be formatted and the OS must be reinstalled upon it. You are getting this error because there is no OS on it currently, according to what you are telling us here.
thanks for using FixYa.com
Positive comments are always welcome
a
Oct 27, 2009 | Computers & Internet
Will removing the CMOS battery clear the BIOS
it's about the processor level caches
but also might be a bad memory slot (RAM)
resetting the bios is a good choice, maybe this will helpe either
Jul 01, 2009 | Acer Computers & Internet
How to disable cahing or shadowing
You can do this in your BIOS settings. When you reboot the computer, look for a message that states what key on the keyboard to press to enter BIOS settings. Usually DELETE key, F1 or F2 key. Look for advance settings tab in BIOS menu. You will see it under there.
Mar 28, 2009 | Microsoft Windows XP Professional With...
Acer Aspire 5315 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
