Question about Toys
My micro twister helicopter starts to fly and then after 5 seconds the body starts to oscillate in piitch and yaw and becomes uncontollable it worked well when i first got it. whats wrong with it?
  • seth144144 Dec 07, 2010
    thanks for your comments ill try them out.
Check the flybar connector pin. I bought two twisters and they had the same problem you described after a few hard crashes. I cut a safety pin up and made a C shape that held so i could keep flying that night(the heli had a two foot oscillation ,though). The store where i bought it gave me free replacement pins and said to put a touch of plastic cement across the outside. not zap or super glue as it will cappillary along the pin and glue it to the main upright
Posted on Dec 06, 2010
Ive got the same problem. i bought it only yesterday
Posted on Oct 30, 2010
  • seth144144 Nov 20, 2010
    if anyone else has got a problem because it might be something to take up with the company.
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
My micro twister pro helicopter won,t lift off. all seems to be working fine
If it was the motor gear, the blades wouldnt be turning at all...some ppl are clueless :-/
Jan 03, 2012 | Toys
Hello i just bought a s032g from dealextreme 032 does not start up react to transmitter is zero i folowd the start protocol but noting anny ideas thanks
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Aug 13, 2011 | SYMA Toys industrial Syma S032 Ready to...
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
4) Power on remote.
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
So i have the syma s107 and it as flying great and everything for a few days after a few crashes it still has great lift and what not. but now the whole helicopter like rotates while fying not in a yaw...
Make sure the drive shaft is seated properly. Gently, but firmly push it down towards the body both above and below bottom rotor. Also check shaft for any hair, thread or such thing that may be wrapped around it.
Let me know if you're still having issues, and we'll dig a little deeper.
PvT
Apr 17, 2011 | SYMA Toys industrial New Syma S107 Mini...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
My john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Dec 30, 2009 | Toys
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Toys Logo
1,117 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
