Question about White Mountain F69206X 6 Quart Ice Cream Maker
Motor does not stop
Our White Mountain freezer doesn't stop when the ice cream is frozen. When we take the dasher out, the is a layer of frozen ice cream around the container but the rest of the ice cream is soft.
  • 1 more comment
  • sdbrightwell Jun 30, 2008
    We've had a White Mountain hand crank ice cream maker for several years now and it has worked beautifully. Just recently (the last 4 times we've used it), we have had trouble with the dasher not scraping the sides of the container so there is a layer of frozen ice cream and the rest is 'soup'. Also the dasher freezes to the sides of the canister and cannot be pulled out and has to be 'melted out' by running hot water on the outside of the canister. We are using a recipe that has Splenda in it and wonder if that could be the problem, but have used this recipe successfully before. Would appreciate any suggestions. Thank you!
  • michellecrai Jul 06, 2008
    will not freeze ice cream motor runs fine just remains soupy
  • mlgriffin07 Aug 18, 2008
    Our Ice cream freezer is not working right this is only our 5th time to use it and it is only freezing a thin layer around the edge and then there is a black liquid on the inside top of the lid.
    Problem Solver:
  • 15 Answers
If the ice cream is frozen on the inside of the can and soft toward the center, I would check your paddles. The paddles are wooden and they attach to the outer dasher with two screws. If the screws are too tight or too loose, then the paddles will not scrap the frozen cream from the inside of the can, resulting in what you describe.
Posted on Jul 16, 2012
If you check the instructions that come with the white mountain ice cream maker, they talk about the problem of the custard not freezing in the center. It is because you have your salt to ice ratio out of whack. Too much salt causes a situation similar to your description. You want to shoot for 12 degrees and if you add too much salt, it goes lower than that.
There are copies of the original instructions online (usually in a pdf file format) that are worth looking for and reading. Rule of thumb 1 to 5 ratio of salt to ice.
Posted on May 27, 2009
Broken Gear
This might be helpful.
http://home.hiwaay.net/~karthur/Freezer/White%20Mountain%20Motor%20Repair.html
Jan 02, 2014 | White Mountain F69206X 6 Quart Ice Cream...
Motor will run but the buckle will stop turning when you add ice
That usually means that the gears in the unit need to be repaired. This might be able to help.
White Mountain Ice Cream Freezer Motor Repair
Sep 09, 2013 | White Mountain F69206X 6 Quart Ice Cream...
White Mountain 69204 ice cream motor gear slips
Sometimes the gears in the unit become worn and have to be replaced. This might help.
Sep 04, 2013 | White Mountain F69206X 6 Quart Ice Cream...
Does the dasher move on the ice cream maker or just the canister?
The dasher rotates, driven by the motor. The canister isn't supposed to move, but sometimes will depending on how thick the ice cream mixture gets. Presumably, if the ice cream were to freeze hard enough, the dasher would find it harder and harder to turn, until eventually the entire canister, with the dasher embedded in the ice cream, would start to rotate in the ice.
Mar 04, 2011 | Nostalgia Electrics ICMP-400BLUE Ice Cream...
Why won't the freezer freeze the ice cream? It freezes around the outside of the cannister only.
According to White Mountain, this happens because the ice brine gets too cold. The procedure they recommend is as follows:
After you put your cream can in the tub and attach your crank or motor, fill the tub with ice and run for two minutes to cool the cream can. Then, put two cups of rock salt on top of the ice and let it continue to crank. After the ice level has dropped 2-3 inches, put more ice on top and another two cups of rock salt and let it continue to crank until the ice cream is done.
Sep 24, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Motor runs top turns but dasher does not turn
We have used White Mountain 6 quart freezers for over 20 years and have experienced this problem with 4 separate malfunctions causing it.
1. For some reason the square shaft at top of dasher does not penetrate far enough into the motor assembly. this allows the dasher to hang free while everything else seems to function properly. We learned that if you have everything ready and want to make sure the outer freezing doesn't occur, place a 3/8 inch slice of a potato over the male spindle in bottom of wooden bucket. This jacks the can up with the dasher inside and causes the shaft to go up into the motor and work.
2. Some cans had a female plate attached to the bottom on the outside to fit down over the male spindale in the wooden bucket. This plate has been known to become detached and lost allowing the can, dasher, and everything to drop down far enough to disengage the square shaft from the motor. The potato slice will usually resolve the problem.
3. A more permanant fix is to remove the male spindale from inside the bottom of the wooden bucket and place stainless steel washers under it to jack it up, and screw it back down with stainless screws.
4. Even if the entire male spindle becomes detached and lost from the bottom inside of the wooden bucket, we have found that a healthy potato slice works as a temporary fix. While the spindle is designed to keep the can centered in the wood tub, once the ice is placed around the can, it seems to stay centered and makes ice cream.
5. We think we have improved the situation on several occaisions by tightening the screws holding the wood scrapers to the metal dasher. We try to leave a little looseness in the screws--about 1/4 inch of free play. The scrapers are designed to pull out against the inside of the can as they turn and resistance to the mix occurs, but we think it is possible for them to be so loose that they get hung slightly away from the edge of the can and once freezing starts, it continues to multiply and creates a layer of insulation leaving the inside liquid.
6. At one point some of the lids were made of a very light aluminum type material. A tab on the inside of the rim of the lid was also light metal and attached in such a manner that they could become detached or distorted so that it failed to mate up with the tab inside the can. Current models have a heavy molded lid with the tab molded into it. We never had a problem with the molded lids, but practically all the light weight ones eventually failed. As the lid turns it's tab engages the tab inside the can and turns the can with the mix in it. If the tab becomes distorted or broken, the lid will turn normally and everything looks great, but the can of mix is standing still with no stirring. Therefore a film of freezing mix forms around the inside of the can.
7. Sorry about overloading you with information, but you probably can resolve your problem with one of these fixes.
Jul 18, 2010 | White Mountain F69206X 6 Quart Ice Cream...
White mountain freezing problem
NO SOLUTION but I have this same problem with my machine.
Jul 04, 2010 | White Mountain F-69204-X Ice Cream Maker
The motor runs but it will not turn the dasher.
dasher is supposed to be statioary so it can scrape off the frozen mix as the cannister turns. That is the secret to mixing the frozen mix into the unfrozen part to thicken the mix in the can. It pushes the frozen part toward the middle as it scrapes it.
Mar 21, 2010 | White Mountain F69206X 6 Quart Ice Cream...
I purchased a rival ice cream maker. I used it once and the ice cream came out great. The next time I used it the paddle didn't turn and the ice cream and paddle was frozen to the sides of the can. The...
The tub turns around the dasher(paddle). You live in a high humid area... to much ice and salt around outside. Plus you need to age the ice cream a few hours after mixing. See your book.
Jul 07, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
White Mountain F69206X 6 Quart Ice Cream Maker Logo
374 people viewed this question
Top White Mountain Ice Cream Makers Experts
Dennis Boxerman
Are you a White Mountain Ice Cream Maker Expert? Answer questions, earn points and help others
