Question about Sony Hi8 Hi-8 Tape
WHEN PLAYING TAPES BACK THERE IS NO PICTURE UNLESS YOU FAST FORWARD OR REWIND WHILE TRYING TO PLAY IT.
  • Sony Master
  • 5,113 Answers
This sounds like you need to clean the video heads.
Posted on Oct 12, 2010
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Audio Players & Recorders
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
Jan 20, 2008 | Video Cameras
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Sony Hi8 Hi-8 Tape Logo
153 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
