Question about Zanussi 24 in. DA6141 Built-in Dishwasher
My dish washer is not washing the dishes on the top shelf and leaves a sand like residue on top of the cups and glasses. I have washed out the top spraying arm and washed the dish washer out with vinegar.
  • Zanussi Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 03, 2011
Leaves food residue on dishes, mostly glasses and only on top shelf after every wash.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Jan 16, 2011 | Whirlpool 24 in. GU1200XT Built-in...
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
Jun 22, 2010 | GE Dishwashers
I have just moved into a new rental & the Technika Bellissimo Dishwasher isn't cleaning the dishes particually on top shelf. I have cleaned dish washer from top to bottom (arms as well)It is driving me...
That looks like the Washing powder residue. I am having a similar problem. But I am finding that the heating element isn't working anymore and hence can't rinse with hot water thus appears the soapy residue which dries into a 'sandy' substance as you say. Sorry no solution for you yet, can you check if when it finishes and you open it - its still hot inside?
Apr 02, 2010 | Dishwashers
Dishes on top shelf, usually cups and glasses, not washing correctly. Have tried rinsing cl eanser to no avail
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. Might also be worth checking the other 2 spray arms at the same time.
Jan 25, 2010 | Belling 24 in. IDW602 Built-in Dishwasher
Anything I put on the top rack is not getting clean anymore. Residue remains (but now gets dried on) and it seems like residue that was on other dishes gets washed on glasses and cups that had no residue...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 15, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
White residue on dishes after wash
check if the residue are soap or not. residue could be from water tank or water itself.
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
259 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
