My comp keeps on freezing. When it freezes I can usuall y still move the mouse. There are also pin stripe kind of lines that may appear on the screen. This usually happens when I grab and drag items. What can I do to fix this problem. My comp is an Emac.
    Sergeant:
    Champion:
  • 326 Answers
What os? Have U cleaned it and defraged lately?
Posted on May 26, 2008
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
My laptop when i turn it on and when the home screem comes up the mouse freeze up cant move to go any where
I assume you are using a USB mouse? Try the mouse on another machine. Try another mouse on tour machine. Is the problem moving with the mouse? What kind of mouse and what kind of computer and the OS you are using?
Dec 17, 2012 | Compaq Computers & Internet
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Mouse Pad freezes
Will you please try these.
FN+ Following marked ker.
36a19f7.jpg Thanks & waiting for your feed back.
Feb 10, 2010 | Samsung NC10-14GW PC Notebook
G5 Graphics Card Freezes or begins to show lines on display
Since you are able to see your mouse pointer move, the display is refreshing so the problem is with something other than the graphics card. Generally software / OS related.
So assuming you aren't experiencing a hardware failure try the following...
Boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot from the CD
If so run disk utility from the CD and repair the disk as well as permissions. If there are any errors repair again.
If this is successful your computer "should" be repaired. If it is still freezing, use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Cheers
Mar 02, 2009 | Apple iMac G5 Desktop
Hp s3120n slim line freezing up
Sounds like a video issue. What OS is on the machine? Try updating the video card drivers. If the OS is Windows 2000 or older, update your version of DirectX as well.
If that doesnt work, check system resources. Low memory, and low hard drive space can be a cause.
If all else fails, replace the mouse. Mice are very inexpensive now. Keep us posted.
Feb 28, 2009 | HP S3120N Pavilion Slimline Desktop...
Mouse freezes when i move it on desktop or a window.
hi, ok go into control panel,printers and other hardware-mouse -slow the pointer speed a notch at a time. this should help. good luck,glen
Jan 04, 2009 | Microsoft Wireless Optical Mouse
Logitech Mouse
Where do you have the transmitter sitting? If it is below a desk (i.e., sitting on top of the computer tower, etc.) it may not be emitting a strong or consistent signal. Try moving it within a clear line of sight to the mouse. If that doesn't work, it could be a problem with the mouse itself and need to be replaced.
Hope this helps, let me know
~ Genie-Us IT
Jun 25, 2008 | Logitech Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
