Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water filtration system
Where is the eject button?
It's down near the floor, under the freezer door. Push it in and the filter beside it will pop out.
Posted on May 26, 2008
2 Suggested Answers
  • 56 Answers
SOURCE: Filter for UltraEase water filtration system?
This may not be the problem now but by the sound of the malfunctioning water lines etc., it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
Purchasing a water filtration system for a house
This is very location dependant. Different parts of the country have different needs. I suggest that you contact 3-4 companies and have them submit proposals. They should take a sample of your water, analize it, and then make a reccomendation based on your needs.
Apr 15, 2014 | Water Heaters
Do I need a home water filtration system?
The benefit of home filtration system is that they are passive; they require no electricity to filter the water. As long as the cost of replacement filter elements is reasonable, owing a home water filtration system can be very cheap, and it is worth it.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
I work at a church that is using the AquaBrew TE1216 coffee brewer, but no one can find the manual for it (it's been here for several years). Right now, the bottom red light for the water quality indicator...
These brewers have a timer system in them based on (I think) a 6 month timer. The LED is not an indicator of actual water quality - it is just a reminder to change your filter every 6 months. To reset it, loosen the screw on the top cover and lift the top off. You will see a push button on one of the circuit boards. Hold the button in for several seconds and the timer should reset. Also should check the 9V battery and possibly change it while you are in there.
Feb 07, 2011 | AquaBrew TE-1216 Coffee Maker
Water pressure gets very low . GE GNWH38F FILTRATION SYSTEM. HELP !
This generally indicates the outlet manifold on softener is partially plugged. This needs to be removed and either cleaned or replaced.
RJ
Sep 17, 2010 | General Electric GE SmartWater Household...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
My GE Filtration system tank does not fill up with water .. The connections look fine
Try loosening the lid .Allow the water to run when the tank is full of water tighten the lid.I beleave your air locked Hope this works for you.
Dec 02, 2009 | General Electric GE SmartWater Household...
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric GE SmartWater Household...
before putting cover on, chk the button to make sure it isn't staying depressed and see what the button is doing when depressed. The cover may have to be in a certain position. with the cover in place, gently rotate untill button pops up
Apr 22, 2009 | General Electric GE SmartWater Household...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
155 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
