Question about Compaq Armada E500 Notebook
No DISPLAY ON THE SCREEN
MY E500 DOESN'T NOT WANT TO DISPLAY ANY THING. THE DISPLAY CAN COME ON SOMETIMES AFTER HOURS. There is no problem when using an external screen connected to it. Could someone tell me what to do "? Thanks...
    Genius:
  • 1,027 Answers
If the external display works fine then the most common fault is the Inverter board for the LCD. By having the external display function properly, the video signal from the video graphics card is working.
The other fault could be, but generally isn't, the TAB welds on the LCD. Usually when these go a portion of the display will be lost first or discoloration e.g. red/white/or black stripe appears.
I generally don't include the CCFL (Cold Cathode Florescent Lamps) as a fault as the inverter is what supplies the voltage to the lamps.
Posted on May 26, 2008
LG E50 display problems
This is related to heat problem, resulting of bad manufacture of the motherboard. It hapens with some model of motherboard. I\'ve fixed some. You have to open the laptop case and find the GPU and CPU chips (See the manual or google for the manual of you board to locate them). Then see were the thermall mass is and wipe ip clean and replace it with fresh one. Clean the fans of all dust and mount everything again. That should do it.
Mar 28, 2013 | LG E500 Express Dual Series Notebook PC
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
E500 + fl50
you don't have to see the flash on the screen.
if the flash is on tll than he adjust itself to the camera setting
Aug 09, 2009 | Olympus E-520 Digital Camera with 14-42mm...
My mpc, on turn on does not display, but black screen for hours
Use whatever software you have or can get to check the memory. Use task manager to see how busy your memory is, and it will check other stuff too.
May 04, 2009 | Computers & Internet
Compaq armada e5oo laptop...right side of screen looses brightnes
It sounds like the inverter on your LCD screen is going bad on you.  You can sometimes find inverters for cheap on eBay, but you will need to get the part number from Compaq to be sure that you are buying the correct thing, and I usually say not to buy any that ship from Asia even though they may be cheaper, as many times they are knock offs.
Mar 30, 2009 | Compaq Armada E500 Notebook
Evolt E500 Olympus - Black / Blank LCD Screen
so u are saying that ur camera is taking pics perfectly but u r unable to see them on lcd but u can see them on PC is that so then ur LCD is faulty offcourse is there any button to toggle lcd on/off if it doesnt help then my dear get it replaced
but if u can see some signs on lcd like info or something then my friend the problem is bigger than u think it is CCD failure
let me know if i can help u in this more and pls do vote me
Feb 24, 2009 | Olympus EVOLT E-500 Digital Camera
Analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
Display problems
Hi,Have you installed new RAM recently?if so it might not be properly seated,it's worth reseating it and see if that helps,or try removing RAM sticks alternately it may be a faulty one.
Dec 22, 2008 | Compaq Armada E500 Notebook
Black screen
I'd reseat the memory first. If there are two pieces, take first one, then the other alone in the system. Possibly bad memory. If that's not it, the lcd cable could be unplugged. Try connecting to an external monitor. If that works, it's the lcd somewhere.
Good luck
Nov 22, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
