Question about Konica Minolta Office Equipment & Supplies
Toner hoper motor is not moving - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Expert
  • 1,326 Answers
What model?
Posted on Oct 02, 2010
Error code 000025
Plz chek the hoper unit delivery & round motor. the moter has not running
Jul 24, 2014 | Canon ImageRunner Color 3480 | IRC3480 |
Minolta cspro ep 6000
what is the code 0070 ??? what about the motor?????
Apr 18, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta 600
This error code has three main reasons. First of all toner spilling occured and the two sensor that detect toner bottle are dirty and should be cleaned, also form the toner hoper that rotate the toenr is defective and should be changed or developer material should be changed. In my experince clean the two sensor that detect the toner and change the developer material and the code will not show it is the most efective way of dealing with this error.
Mar 10, 2014 | Konica Minolta bizhub Office Equipment &...
My ir2230 had error e00024 at first, on opening, the toner hoper was full and toner had poured down to laser unit. i emptied the toner hopper and the developing unit, then on switching the machine back...
first did you connect all connectors correctly on laser unit and reconnect connectors on DC controller?
If You replaced the laser unit assy, without result, only thing that you can try to, is replace DC controller.
For service manual, emma.servis@gmail.com
Hope that helps!
Jun 12, 2011 | Canon imageRUNNER 1630 Copier
Canon np 4050 eror cod e020
e0020
the toner does not move down.
the problem possibility :
- motor of toner not moving and can not pull down the toner
- sensor of toner no detect (check the socket of it perhaps it's just loosen)
- or empty toner.
May 25, 2011 | Office Equipment & Supplies
My gestetner DSM735 keeps saying add toner. replaced toner and developer still saying add toner
The first thing i can tell you is that is weird!!!!
Because if you change the developer that error should disappear. It could appear later but not in the moment because the developer already have toner and the TD sensor will read it.
And that's the question: When you said "replace developer" you mean just the developer or the DEVELOPER UNIT??? Is your TD sensor working good????
Feb 23, 2011 | Gestetner DSm735 Black and White Copier
How to change the toner to my canon np 6045
There is a panel you open on the Right side of the keypanel.Insert the bottle upsidedown and hook in place slide the plastis handle of the hoper unit to the right and the toner will fall from the bottle inside the hopper unit.Close the hoper unit slide before removing the toner.
Dec 09, 2009 | Canon NP 6050 Copier
Minolta bizhub 420 code c2403
this error code means there is a problem with the toner bottle drive most likely the toner rotation sensor will need to be replaced
Nov 21, 2009 | Konica Minolta Office Equipment & Supplies
Entry into service mode
I need to Know what you mean by purge you toner, The Service mode is use for trained tachnical reps only and if you have had access to this mode you could do more harm than good. the toner ager system of this machine will through a SC592 code if you turn on the Coil and drive to move toner through it unless you kow what you are doing.So a little more info may help me help you.
Jun 03, 2009 | Ricoh Aficio 1085 Laser Printer
15 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
