Question about Siemens Gigaset C200 Cordless Phone
Siemens 200 gigaset gone dead, not charging - Siemens Gigaset C200 Cordless Phone
4 Suggested Answers
CORDLESSGURU
  • 106 Answers
SOURCE: my siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Posted on Jan 11, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
  • 6771 Answers
SOURCE: my siemens gigaset AS 140
The battery in the phone needs to be replaced, because it is at the end of the charging cycle and the usage becomes less over time.
Posted on Feb 07, 2011
How to lock handset
You should look up function in your user's manual. If you can't find it, you can't lock handset:
Manuals Gigaset
Manuals Gigaset
Manuals Gigaset
Siemens Gigaset A490 White Cordless Phone Unboxing
Aug 28, 2015 | Siemens Gigaset A490 Twin Cordless Phone
Cordless ph. not holding charge
You should check battery with oher charger. If charges, your problem is tha charger of your phone. Probably you should take it for service and if to expendive, buy a new one
Feb 10, 2015 | Siemens Gigaset 200 1Line Cordless Phone
Not showing correct battery level
remove batteries; put batteries back. The level will return to normal
Feb 18, 2013 | Siemens GIGASET-S795 GIGASET-S795
Siemens Gigaset 4200 Cordless keep searching for base
The handset should be returned to the charging station, let it set for a few seconds. If this is a satellite phone, make sure the main phone "base unit" is connected to phone outlet and plugged in. After the phone has established its physical connection with the base again you can remove it and use it like normal.
May 18, 2012 | Siemens Gigaset 4200 Cordless Expansion...
Gigaset showing no base n hand set display, how do we fix it?
Off hand I would say your battery is totally dead
May come back with an overnight charge
Jan 30, 2011 | Siemens Gigaset 4010 Cordless Phone
Cordless phone won't charge.
take a pencil eraser and clean off the contacts on the cradle and one the phone itself, they may just be dirty.
May 27, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
May 23, 2008 | Siemens Gigaset 4000 Phone
Siemens Gigaset C200 Cordless Phone Logo
96 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
