Question about Cooler Master (CAC-T05-UW) (CAC-T05-UWA) ATX Mid-Tower Case
A Power supply that fits in a cooler master case
    Master:
  • 397 Answers
You could use the following (mind, I tend to go for the 750-1k watt powersupplies since I tend to be a bit of a hardware fanatic- and want more than enough power to run my gear. )
Check a site like Newegg.com (here's a sample search: http://www.newegg.com/Store/SubCategory.aspx?SubCategory=58&name=Power-Supplies)
The brands I prefer are Corsair, Antec, Zalman, and Coolermaster. You can go cheaper, but I do not recommend skimping on your powersupply. It is the *number one* source of pc headaches when you are building a system. Get the best your money can afford- you will be happier in the long run. Also, don't go under 700 watts- most gaming rigs can draw that much as a minimum- and the more wattage = the more room to expand and upgrade down the road.
Posted on Oct 01, 2010
Need a power supply
To choose a power supply you first need to know how much power the computer needs on maximum load and what hardware needs to be powered. As this information is not given its hard to answer this question.
The general answer is look what kind of connectors you need for the power supply to have and pick one. As all the ATX power supplies will fit in the case
Aug 27, 2012 | Cooler Master CAC-T05-UW ATX Mid-Tower...
What power supply is compatible with a cool master CAC-T05-UW? ATX Mid Tower ATX, Micro ATX compatible form factor 2 External 5.25drive bays 2 External 3.5 drive bay 2 Internal 5.25 drive bays 7...
Hello vonii94,
Welcome, and thank you for using FixYa!
To answer your questions, the sky is the limit! :)
Any modern power supply you would purchase, as long as it is ATX Compatible, will fit this box.
I recommend at least a 750Watt so that you have growing (upgrading) room in the PC. Antec and Cooler Master make some nice ones.
www.newegg.com or www.tigerdirect.com
Have a great day!
Sep 12, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Researching power supply for Cooler Master CAC-T05-UW Must be ATX MidTower, ATX compatible form factor,2 external 5.25" drive bays,2 external 3.5" drive bays,2 internal 5.25" drive bays,7...
The power supply will fit... the question is what do my motherboard, video card, ans drives need in wattage. most systems will do well with a 650 watt. I like antec as a brand.
Aug 29, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
What power supply is compatible with cooler master cac-t05-uw? \
Good Day
The same model also comes standard with a 390w power supply. However it all depends on what you are using the Desktop for, what you want the power supply features to do and what you install in the casing. Amything above 390w will do for general desktop work. If a gaming desktop, anything above 500w should do. You should obviously use the same brand Cool Master power supply but most brands should fit. Take a picture of the back of the case where the power supply fits and take it with you to a store if not sure.
here is a ling to give you some ideas. http://www.coolermaster-usa.com/category.php?category_id=22
regards
Shaun
Jul 14, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Power supply compatible for cooler master cac-t05-uw
Most brands like HEC, Gigabyte, FPS, Cooler Master, Enermax, Silver stone, Corsair, etc. Will fit in your casing but you must consider your hardware before buying a power supply.
Most power supplies that are priced below $30 generally do not meet the power requirements of the latest processors. To make matters worse, the components used in them are of inferior quality and more likely to fail over time. While they may power the computer system, inconsistencies in the power to the components will tend to cause instability and damage to the computer.
Consider the ff:
ATX12V Compliant
PC Power Supply Wattage
Silent PC Power Supplies
Power Efficiency
Having the right number of connectors
PSU Wattage Calculator Asus
PSU Wattage Calculator extreme
Hopefully this helps..
Thank you for posting..
Jul 08, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I NEED POWER SUPPLY FOR COOLER MASTER CAC-T05-UW
There are several things to consider. How much power do you need? This all depends on your accesories such as hard drives and cd drives and what type of processor you have. You can go to a local computer store or an online store like Newegg.com or Tigerdirect.com and do a search for an ATX power supply. Here is a link to a good power supply that will fit your case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182006&cm_re=atx_power_supply-_-17-182-006-_-Product
Feb 10, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I need a power supply compatible cooler master cac-t05-uw
Power supplies are standard size. Buy one that has at least 500watts power. If gaming, I suggest a power supply with dual 12v rails
Oct 18, 2010 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Power supply compatible with cooler master cac-t05-uw
Power supplies are not matched to a case. Any one you buy will fit in the case. You need to make sure it has the correct power capacity and plugs for your motherboard, video card, and anything else you will have plugged into it.
Mar 27, 2009 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Cooler Master (CAC-T05-UW) (CAC-T05-UWA) ATX Mid-Tower Case Logo
345 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Chris Larocque
Jay Plesset
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
