Hi i have a elonex 37' inch tv remote control jc78bb13e t73b and it is not working. i need to change the size of the screen on the tv. any ideas or helpful tips
SOURCE: Proline tv remote control code.
try 0067 0568 0655 0664 0321 0102 0651 1406
good luck
Posted on Jan 03, 2008
ctf1800
  • 4402 Answers
SOURCE: tv. does not turn on sometimes? philips 63pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
  • 26 Answers
SOURCE: RCA Universal Remote Code
Here are the codes for Philips. If these do not work you have to use the code search feature.
Philips........002,006,007,010,011,013,016, 033,035,037,038,043,066,073
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD,
SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button,
for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-7.
Posted on Nov 17, 2008
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
The screen size on my tv needs adjusting . How do I do this thro' mt Sky remote?
The screen size is also called the aspect of the TV. look in your menu for aspect ratio.
Dec 15, 2011 | LG 37LG50 37 in. LCD HDTV
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I have a new 37 inch led/led samsung tv. picture is larger than screen size by about 20 % how do i reduce it to screen size.
should be a button on the remote that says "P.Size" Every push of the button changes the Aspect, should be set to either 16:9 or Full. Hope this helps. If you do not have the remote, you can access thru the menu button on the set and toggle thru on screen display to Viseo and adjust it there as well. Hope this helps.
Jan 11, 2011 | Samsung Televison & Video
Hi i have a elonex 37 hd lcd tv and have just brought a bluray dvd it is not working on the hdmi lead
I have same problem with Elonex 37". Sadly I think it is because the HDMi specification was amended and newer products (such as your blu-ray ) simply do not connect. My blu ray did until I downloaded newer firmware then nothing. Same with my (new) Freesat HD box - nothing. But an old media player still works over the HDMi. I am checking if there are any solutions but I doubt it. Use the YPbPr connector - your blu ray probably has this and the TV does.
Jan 03, 2011 | Televison & Video
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
My tv picture is to large for the screen how do i reformat the size
a lot of the newer tv's will have a zoom button on the remote which will change the size of the picture to settings like normal, wide cinema...
Jul 19, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
