Question about Olympia Mastertype 3 Typewriter
It appears that someone has set my type writer to print an alternate charector set. I need to know how to correct this. lots of words that look like*@%$UYHS#@> or similar.
  • Olympia Master
  • 3,594 Answers
There is a very good chance that the pitch selectot slide switch on the L. side of the keyboard is in the PS position it should be in 10 or 12.
DickyO
Posted on Oct 01, 2010
Typing Arabic way
if it is printing the correct words it is most likely set for right margin flush turn the right margin flush off
Apr 07, 2014 | Nakajima AE-800 Typewriter
Inserting a word between other words without typing over the words already there!
The keyboard of a computer has a key marked INSERT. It toggles between Insert and Overwrite. The default is insert.
Nov 17, 2013 | Activision Typing / Resume Writer (Jewel...
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
Feb 27, 2013 | Brother SX-4000 Typewriter
When I attempt to convert a word document into an PDF file I get a message "missing PDF maker files" I'm given the option to say yes or no to "do you want to run the installer in repari...
From the info you provided, seems like your Adobe Acrobat Professional wasn't installed properly or there are some missing files.
If you have the installation file, try installing the software again.
(When you click on Yes, nothing happens because adobe cannot find the Installation/setup file on your laptop.)
If you do not have the Adobe installation files, as an alternative download CutePDF writer. Its free and hardly takes any space on your pc/laptop (<4MB)
Direct Download Link for CutePDF
Once downloaded, install the software and follow the steps below:
1. Open the Word file you want to convert to pdf
2. try to print it
3. before printing, the time when u have to select your printer, select Cute PDF Writer as shown in the image below
4. Click on print
5. The Word document will be printed as a PDF file and you'll be asked where you want to save it :)
6. Choose your destination.
7. When the printing is completed, you can open the pdf file in Adobe PDF reader
* You don't need a printer to do this
* You can follow the same steps and print excel/powerpoint files to pdf (or any other file type that you can "print")
Hope this helped!
Mar 31, 2011 | Adobe Acrobat 7.0 Professional
It appears that someone has set my type writer to print an alternate charector set. I need to know how to correct this. Lots of words that look like *&UYJH$#@> or similar.
Ckeck the pitch selector slide switch it should be in 10 or 12 not in PS. also slide it up and down a few times they do get dirty.
DickyO
Sep 27, 2010 | Olympia Mastertype 3 Typewriter
How to print envelopes?
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Jun 03, 2010 | HP DeskJet 940c InkJet Printer
Ricoh laser printer will not correctly print my envelopes - need someone to help me calibrate the printer or the word program to effectively print envelopes
what model? you must tell the printer what envelope type is in the bypass (must use bypass) usually type 10. also must tell word in print properties to feed from bypass, again usually type 10 envelopes
Aug 04, 2009 | Computers & Internet
Printing incorrect letters
Check the pitck selector slide switch it may be in PS this will give you that problem.
DickyO
Apr 06, 2009 | Olympia Mastertype 3 Typewriter
I have a Brother QL-550 label writer and I need to do some printing in MS Word 2003. I have done this inthe past with a specific label size. I haven't changed anything in my settings and when I look at my...
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Brother P-touch QL-550 Thermal Label...
Help
1. Verify the wireless security which is enabled in your router
2. Check the type of the security enabled in it. It could be WEP(64 or 128) or it could be WPA
3. Make sure that the correct security is enabled in your XBOX
Aug 26, 2008 | NetGear DG834G Router
Olympia Mastertype 3 Typewriter Logo
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
