Question about Kenmore Oasis HE 27082 Top Load Washer
LF Error Code
My washer gives me an "LF" error code in the wash cycle what should I do?
  • 3 more comments
  • hilbuscat May 26, 2008
    I just started hving the same problem but only in the towel and sheet mode. Will more than likely have to buy a board but not till it craps out completely. The LF code stands for long fill time.
  • bkjones3 Aug 19, 2008
    LF code. Only in the normal mode at 17 min. left it stops and flashes LF. Also the fabric softner does not dispense in any cycle. There 1800 number is terrible and no one ever calls back, got no where with anybody. So called mechanics have ben here 5 times and guessed about problem. They replaced the fabric dispenser and the control module. Still same problem. Washer is only 6 months old. Filed a BBB complant and now Sears is giving me a full credit to purchase another washer. Any ideas on a great HE top loader washer?
  • Anonymous Nov 18, 2008
    I just received my washer today and on my first load, not more than 15 min. into it the LF code appeared. I try to restart it and with in two mins. LF appeares again!!!!
  • Anonymous Mar 15, 2014
    LF error washer won't fill
  • chris
    chris Sep 12, 2014
    i have just pulled up on basket and then restarted
I get this problem every year or so, especially when my wife washes large items like comforters. Usually, it gets through the wash and rinse but throws the LF error code and quits before spinning all the water out!
The problem is never related to drainage issues, but rather it's always a badly calibrated (or possibly failing) water level sensor. To cure this problem, I go into the manual self test, turn on all the drain pumps to remove as much water as possible, then recalibrate the water level sensor. To perform these steps, I do the following:
To enter the self test mode, I do the following:
1. Make sure all the lights are off by hitting the Stop/Off button.
2. Press the "Clean Washer" button and hold it down for 3 seconds. Then release for 3 seconds, then pres and hold for 3 seconds, repeating this sequence 3 times before all the lights come on indicating that I'm now in the self tests.
3. Once in the self test mode, I again hit the "Clean Washer" button to tell it that I want manual self tests. If you don't do this within a certain amount of time, it automatically starts the automated tests, and then you have blown it and have to hit stop and start all over!
4. While in the manual self test mode, I use the "Clean Washer" button again to cycle through all the pump functions. The first time you hit it, it starts the recirculation pump. The second time you hit it, it turns that pump off. The 3rd press starts the drain pump, which I let run until it sounds like no water is being removed. The 4th press of this button then turns off the drain pump.
5. Once I have emptied the outer tub of as much water as I can remove, I hit the "Cycle Signal" button to calibrate the water level sensor.
Most of the time, this cures everything; however, it didn't get us through this huge comforter this morning. I suspect I will have to replace the water level sensor once and for all, but for today, I thought up a way to get the water out of our comforter and I want to share that with you as well.
I followed steps 1 through 3 to get into manual self test mode. From here, I commanded the washer to spin the comforter around a few times so that we could finish the wash. To do that, you do the following:
1. Lock the lid by pressing and releasing the "2nd Rinse" or "Extra Rinse" button. You should hear it click and the red light should come on. You need to do this or you can't fire up the motors.
2. To start spinning at 23 rpm, you hit the spin speed button once. I let it ramp up and then hit it again to speed up to 530 rpm. If everything sounds ok, I hit it again to go up to 1,000 rpm. As long as it doesn't start making thumping sounds, I let it keep going. If I hear anything that sounds bad, I hit the button again to stop the motor.
You can repeat this process several times until you feel confident that you've removed as much water as possible. You can also use the "Clean Washer" button in tandem with the spin motor to remove water from the washing machine while you spin. This worked beautifully this morning, and I plan to use this trick every time we have problems with large items.
Posted on Mar 12, 2016
  • 868 Answers
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
Posted on May 26, 2008
2 Suggested Answers
  • 6 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Posted on Dec 15, 2007
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
Whirlpool washing machine with error code FL
Dos your machine sometimes continue to fill Fl could be LF I have seen the codes pop up different than the tech sheet anyway LF is a long fill wish I could tell you the exact location of the service manual WP always moves it try on the inside of the bottom panel first if not there look inside might be mounted on wall a few times located under top panel read it it will explain how to place machine into diagnostic usually on LF the unit is draining slow or the black hose that leads to the pressure switch has popped loose a rubbed against basket pulley causing a small hole in the rubber this will give a LF error hope this helps
Feb 13, 2015 | Whirlpool Duet WFW9250WW 4.0 Cu. Ft. Front...
Whirlpool duet washer LF error
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Nov 24, 2012 | Washing Machines
What does LF mean - my kemore washer quit working
hello
mean while LF error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
The LF error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the LF error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LF = Long Fill
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,409 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
