Question about O2 Xda Atom Exec Smartphone
How do I check my processor speed?
I need to ensure the phone I bought is an Exec.
How can I ask the phone what its processor speed is?
After windows starts: start>settings then choose system (one of the three sub-menus) device information and four sub-menus appear, you need hardware sub-menu and it will show you processor type, speed, ram size and so on... enjoy!
Posted on Aug 03, 2008
I have an el1333g desktop it has a amd 64x2 2.4 prosscer in how much bigger can i go
Select the "Start Menu." Click to select "Control Panel." This will open a new window with several clickable options. Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel Click to select "System" from the new list of options Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer. Checking the Stock CPU Speed in Windows XP Click the "Start Menu. Right-click on "My Computer." Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window. Check the CPU rating as listed underneath the "Computer" heading. b> Determining Real-Time CPU Speed Go to CPU Speed Professional's website (see Below) and download "CPU Speed Professional." While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website. Install the recently downloaded " http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html " file by double-clicking on it and following on-screen prompts to complete the automated install procedure. Open CPU Speed Professional. Click "Test Your Speed" on the main program interface. A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension. Get a Faster Processor b> Start by visiting Intel.com (see the Below ) to research and figure out which processor you want. http://www.intel.com/products/processor/index.htm Read the page and click on the links to the different processor families. Once inside the processor families you can look at the specifications and speeds of the processors. There are three main ways of determining the speed of a processor. First is the speed, measured in GHz. The higher the speed (example: 2.4 GHz) the faster the processor. Second is the L2 cache, measured in MB (example: 2 MB L2 Cache). The L2 cache is kind of like the CPU's own RAM; the larger the cache, the faster your computer operation will be. Finally, there is the Front Side Bus (FSB) speed. The FSB speed is the speed that bits of data are fed through the processor. FSB is measured in MHz (example: 1066 MHz FSB). Once you have an idea of the processor you want, continue to step two. Ensure that your processor of choice will be compatible with your current system. You can do this by checking the documentation for your motherboard. Look through the manual to find out what its CPU socket type is (example: LGA775). There can and will be different socket types on CPUs so ensure your processor choices match up with your motherboard before continuing. The socket (or package) type will be listed in the specifications of any processor you look at. Worth noting is that some motherboards also impose a limit for how high the FSB of a processor can be. While a higher FSB processor will still work with a lower FSB motherboard, processors have to go by the speed limit imposed by the motherboard. Keeping this in mind, as long as the socket type is the same on both parts, they will be compatible. Visit Newegg.com (see Below) or a similar computer or electronics store of your choice and nose around the processor section of the site. http://www.newegg.com/Store/Category.aspx?Category=34&name=CPUs-Processors You should be able to find the processor model you are after. Decide on a processor. If you've already done the research suggested in steps one and two, you should have a decent idea of the kind you want. Choose among the models you selected and add it to your cart, ensuring that the socket type of your new processor will match your motherboard. Once purchased, you should receive it within a few days.
Hope this helps.
Jan 21, 2013 | eMachines EL1333G03w (884483010820) PC...
Hi, I'm RKS and have Office 2010 exec to load in my computer but lost the product key. where can I find
You can contact Microsoft for a lost product key. The phone number is 1-800-936-5700. If this is a downloaded version, they will ask for the cedit card number used for the purchase, and the email used. If this is a store bought copy, I am unsure of what questions they will have.
Hope this helps.
Mar 25, 2012 | Microsoft Office Computers & Internet
I have forgotten how to clear my memory card on my SONY DSC-U30. Can you remind mr?
To delete a single picture select it in the view mode[>].
Press menu and select {> icon] then press EXEC.
Select [Delete] then slect [OK], then press EXEC.
This will delete all the pictures.
Ensure the battery is well charged.
Press Menu, select the [ icon <_ ], then select [Format], select [ OK], then press EXEC.
I hope this helps.
Mar 20, 2010 | Sony Cameras
I have a prob where i can't find clear storage thingy when i want to reformat. i bought a second hand o2 xda atom exec so it is flooded with previous owner's messages pictures,contacts and many many more...
You can find the Clear storage in Settings>System>Clear Storage. Just click on the clear storage to bring the phone to the original state.
Make sure to remove the sim card because some times it may delete the contacts info in your sim card.
Aug 03, 2009 | O2 Xda Atom Exec Smartphone
Processor speed loss
It's possible that the XP is using the extra resource or processor usage, and there isn't anything that you can do. However, It's also possible that this machine was configurated for 2000, and that it just needs drivers for XP. You can start by going to IBM's support site and doing a bios flash to the most recent bios, and checking for a chip set driver update, patch, or for for XP. Also check for any processor speed stepping drivers or updated drivers. Try this and let me know.
Aug 19, 2008 | IBM ThinkPad A21m 2628 Notebook
O2 XDA atom exec Voice Speed dial problem
there is a problom in the phones hands free jack get it repaired the problem will go!!
Aug 14, 2008 | O2 Xda Atom Exec Smartphone
Sound error when receive phone calls
first of all uninstall any programme,which you installed,or "CLEAR STORAGE" option use given in programme menu.after then set call notification only to RING.
Jan 13, 2008 | O2 Xda Atom Exec Smartphone
Web problem.
it happens if there is any important file miss from your phone do following : 1. Turn off phone and take out battery 2. Insert battery, and while it boots up press and hold Ctrl + Shift + F 3. After a few seconds you will be asked if you want to format or cancel I recommend having the device open when inserting the battery so you can press the combination quickly. Remember that this erases everything in the machine and it becomes like when you bought it. (I guess you know it, but mentioned it just in case).
Nov 27, 2006 | Nokia 9300 Handheld
O2 Xda Atom Exec Smartphone Logo
154 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
