Question about Ovens
I have a Blanco BSO 635 Oven. Last week the grill stopped working, My wife went to bake a pie this afternoon and only had the oven turned to 150 degree, it cooked (and Burned) in less than 5 minutes... I already have the owners manual, however it is very limited and doesn't offer any instruction on minimal repair or trouble shooting. Any Suggestions or a repair manual would be good. Thanks
catriver
  • 878 Answers
SOURCE: F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Posted on Mar 04, 2007
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
aborcass
  • 2651 Answers
SOURCE: The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Posted on Mar 01, 2008
Krazytech
  • 725 Answers
SOURCE: Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Posted on Jun 04, 2008
jsrock516
  • 5911 Answers
SOURCE: Frigidaire Model FEFL78CSA oven not heating
I apologize for not getting back to you sooner. I tried to respond to your question yesterday, but the web link was not working. Your assumptions are probably correct as the ERC controls all the oven features on an electric range. This is a fairly simple repair job that any do-it-yourselfer can accomplish.
The ERC is easily accessed by removing the back panel of the operator console. The circuit board is screwed in place with a series of wire connectors. Most models have the wire color coding printed on the circuit board for ease of identification. In addition, there should be a wiring diagram located either inside the console, or on the back of the range. This will also list the color codes. If not, I would recommend you label all wiring BEFORE removing to ensure everything is reconnected correctly (a digital camera can come in handy as well).
New ERCs generally do not come with the overlay. This is the plastic printed face-piece that covers the front of the board with all your controls and numbers. Some manufacturers provide this with the new ERC, but MOST do not. The existing one can be reused by carefully removing and reinstalling to the new ERC. You may consider ordering an overlay too if yours is in bad shape.
You can order a replacement at searspartsdirect.com. Pcappliancerepair.com also carries the part for just a few cents cheaper. I recommend the sears website for the helpful exploded view illustrations. Just type in your model number and look under the "Backguard" heading for item number 20 (part #316207529). The overlay is listed as item 20A (part #316220804). If you wish to save a little and order from the other website, use the part numbers provided by Sears for your search criteria as I could not find your model number listed.
Please ensure you UNPLUG the appliance before servicing. No special tools are required. If you have questions, please post back and let me know. I hope this helps you.
Posted on Nov 28, 2008
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
User Manual Blanco Oven BSO 402w
heres a link to free manual site that has Blanco books Results 1 13 of 13
May 29, 2013 | Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Burners light ok, oven will not light
Stop time knob needs to be out; you set it for timed bake. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ge oven problem
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
193 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
