Question about HP LaserJet 4200 Printer
No network connection - 2 rows of asterisks on display panel - help?
2 Suggested Answers
  • 313 Answers
SOURCE: Business InkJet 2800 just displays rows of
it may want to replace the formatter board, call your HP repair center
Posted on Mar 23, 2010
7 asterisks in a row on register tape.
When entering the clerk passwords, they appear as asterisks **** on the tape sometimes, sometimes this code has to be entered before machine will function,security.
check link, press the helpful button
https://www.royalsupplies.com/cashreg/Instruction%20Manual%20A600-601%20ver8%20GOLD.pdf
Jan 22, 2016 | Sharp ER-A320 Cash Register
I need to find my network password can you help?
The password should be stored in any computer which has connected to that router via wireless.
If that computer has Windows 7, there is a built-in function to display the password. Go to:
Start > Control Panel > Network & sharing > Manage wireless
That will being up a list of routers. Find the correct one, right-click and select "Properties".
That will bring up an info box for that router. Select the "Security" tab, The security key (password) will be hidden behind asterisks. Place a check in the box for "Show characters". That will display the password
If the computer which has connected to the router has an older operating system (Vista or Windows XP), then you may not have that built-in password display feature. But you may still be able retrieve the password by installing some specialized software.
Here are two suggested free software programs to display wireless passwords:
WirelessKeyView by Nirsoft:
http://www.nirsoft.net/utils/wireless_key.html
http://www.softpedia.com/get/Security/Decrypting-Decoding/WirelessKeyView.shtml
Advanced Password Recovery by Josh Cell Software:
http://www.joshcellsoftwares.com/2011/08/advanced-password-recovery-password.html
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Advanced-Password-Recovery.shtml
Jan 01, 2012 | Computers & Internet
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
I need to set up my wireless router to my epson 520 all-in-one printer system. I have lost the password to the router (passphrase). Ineed to get it setup. help!
This solution requires a PC running Windows 7 that is already able to connect to the same network that you would like your printer to use.
Depending on how your system works, you could try right-clicking the icon on the bottom right that indicates your wireless connection. Choose "Open Network and Sharing Center" and then "Manage Wireless Networks". From there, choose your own wireless network from the list, right click it, and select "Properties". Another window should pop up. Go to the "Security" tab. From there, you should see "Network security key" with a few asterisks next to it. Directly below, check the "Show Characters" box and the asterisks will turn into whatever password your computer uses to automatically connect to your internet when it picks up your network.
Solution #2
If the above doesn't work, you can always call your internet provider and ask them to reset the password on your router. Keep in mind, however, that if your password is reset, you will have to go and enter the new password into all other computers/devices that connect to your WiFi.
Sep 17, 2011 | Computers & Internet
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
Business InkJet 2800 just displays rows of asterisks,never boots.
Mar 22, 2010 | HP Business InkJet 2800 Printer
How to access the service mode for a IR400s
1. Starting Service Mode and Making Selections
1) Press the asterisk key ' ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' ' on the control panel.
• The display changes to the screen shown in Figure 14-801, indicating the connected
accessories (FEEDER, SORTER, FAX)
Feb 22, 2010 | Canon imageRUNNER 400S Copier
Hello i want to use h LOOK UP
Hi !!
How to implement Hlookup function:
  • Select your data and sort it in ascending order
  • Then type '=HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)'.
    Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string. Table_array is a table of information in which data is looked up. Use a reference to a range or a range name. The values in the first row of table_array can be text, numbers, or logical values. If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value.
    If range_lookup is FALSE, table_array does not need to be sorted. Uppercase and lowercase text are equivalent. You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options in the sort dialog box, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
    Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
    Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
  • If range_lookup is FALSE and lookup_value is text, you can use the wildcard characters, question mark (?) and asterisk (*), in lookup_value. A question mark matches any single character; an asterisk matches any sequence of characters. If you want to find an actual question mark or asterisk, type a tilde (~) before the character.
  • In the example in the Excel training video the sorted data represents the density of water at different temperatures. The left most column gives the temperature in degrees and the top column specifies the 'decimal' degrees
  • We looked up the density of water at 5.4 degrees celsius using the Hlookupfunction.
Still have problems, Check this video on the you tube.
Hope this would help,
Thanks,
Anurag Shukla
Sep 04, 2009 | Microsoft Excel for PC
Not connecting asterisk in my ubuntu system
Has this ever worked for you? There's a nice how-to for Asterisk/FreePBX on Ubuntu here: http://joeterranova.net/wiki/index.php?title=Install_Asterisk
Hope this helps!
Apr 25, 2009 | Canonical Ltd. Ubuntu
Having to re-enter shared secret key in client card utility
With the description you have provided, I presume that you are using Windows XP. Now, whenever we use utilities to manage wireless adapters, they always conflict with the Wireless Zero Configuration (A service in Windows XP which manages your wireless adapters) and mostly your utility is not able to retain the settings provided to it. The best solution would be to disable the Utility and use the Wireless Zero Configuration instead. We can do that by right clicking the icon for the utility which must be available in the system tray (on the right bottom corner of the computer srceen) and there must be an option which says something like - 'use windows to manage the wireless adapter'. Once we do that, we need to make sure that the Wireless Zero Configuration is actually enabled. Please follow the following steps. STEP 1: 1. Click on start -> run 2. Type 'services.msc' and click OK 3. This will display a list of services 4. Try and locate the 'Wireless Zero Configuration' in the list 5. Double click on it 6. Make sure the 'Startup type' is set to 'Automatic' and the status is 'Started' STEP 2: 1. Click Start -> Control Panel 2. Locate the icon - Network Connections (when in classic view) 3. Under Network Connections, right click on the 'Wireless Network Connection' and click on 'Properties' 4. Look for the 'Wireless Networks' tab 5. Look for the check box which says 'use windows to configure the wireless network settings' Any further questions or issues, please get back to me. good luck
Mar 22, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
HP LaserJet 4200 Printer Logo
526 people viewed this question
Seeker5211
Seeker5211
