We are using bdcom s3224 switch. not able to access it through browser? default IP is pinging but not able to access it through browser. please assist us.
    Master:
  • 397 Answers
Try logging in through the console port instead of the web service- bar that, I would contact Baud Com directly to see if there is specific configuration required
Posted on Oct 01, 2010
I have a linksys efg 250 nas that I am trying to access. Can I get some advice on what to try next?
so you have 192.168.1.77 as the default ip address and 255.255.255.0 as the subnet mask.
What Ip address does the computer you are trying to ping have is it in the range of 192.168.1.2 to 192.168.1.76 in the dos prompt and what is its subnet mask ?
type in ipconfig
what is the equipment between the p.c and the EFG250
what connects it to the network ? A switch are cisco vlans involved or cisco port filtering ?
Dec 03, 2015 | Linksys new networking accessory efg250...
Unable to access settings of d-link modem dsl-2750u
Your Connectivity may be on Wifi or Lan, ping the gateway and verify gateway IP is up and running if not then try to manually assign the IP to the system and try ping and if there is any proxy Please also remove the proxy from the internet settting and if still problem.Then reset the modem and then also set the IP of your system 192.168.1.2 and access the by default IP 192.168.1.1 and configure the acces point
Nov 27, 2013 | D-Link Computers & Internet
Belkin f9k11009v1, Macintosh unable to connect
First see if you are able to connect to the internet wired to the router,
-If you are able to connect using the wire connection then I suggest to turn off the wireless security settings for the time being and see what happens.
Wireless
See if you are able to ping your router.
Ref: http://www.wikihow.com/Ping-on-Mac-OS
-Make sure that the TCP/IP settings are set to DHCP and make sure that it is getting an IP address and Default Gateway.
If you are able to ping the router then see if you are able to ping google by name and by IP. (An IP address for google,com is 74.125.141.100)
If you are able to ping both then you should be able to access the internet.
If you are able to ping only the google's IP address then you have a DNS issue.
-See if you can set your DNS address manualy to 8.8.8.8 and 8.8.4.4. Ref: https://developers.google.com/speed/public-dns/
If you are able to ping only google by name then see if you are able to access google by typing in the replied IP address in the address bar of your web browser on a computer that is working fine.
-If you are not able to access google with the address then you may have something stooping you on your machine. Check for firewalls and antivirus to see if they have any network configurations.
Dec 18, 2012 | Belkin F5D7234-4 Router
My laptop will not connect to our wireless router at work. It says connected, but no internet access.
The laptop might be connected to your wireless router but is unable to connect to the internet
check if you can ping websites
- click on start > Run > type in "cmd" > in the command prompt type in "ping www.yahoo.com"
- if you get 4 replies the problem might be with your browser.
- if Ping fails try typing "ping 209.191.122.70" which is the IP address for www.yahoo.com
- if ping is successful then the issue is with your DNS server. contact your ISP to get alternate DNS
- if Ping fails try pinging the default gateway or modem IP (you can find the default gateway by typing IPCONFIG)
- if ping is successful then there is a problem with your internet provider
Also you should try disabling your firewall and runnning a virus/malware scan
Mar 30, 2011 | Computers & Internet
Can't connect to configure password for linkys wcg200 ver2
It`s a Linksys or a Dlink?
Use IE (some router reffuse other browsers)
Enable java on your browser.
Check router default address with user manual
If still cannot open: Reset Router to factory default.
Connect using cable and setting your PC on same subnet.
If no connection consider a possible firmware corruption (=repair shop OR new device).
Jan 20, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Automatically ping and trace disabled after PBR
please add me on yahoo messenger or mail me , let me know when ur online , my id is samrat101@yahoo.com and we will be able to resolve it sooner,,, mails takes time.
Samrat
Feb 20, 2008 | Computers & Internet
Route-map policy block the ICMP
honestly, I dont think anyone here will know how to handle this problem. Try to show this problem to a trained professional.
Feb 18, 2008 | Computers & Internet
ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Cannot access my modems home page.
Nore than likley that is the default LAN IP address that came with the device. It has probably been changed during the initial setup. A quick way to tell is go to your start button/ select run / type in the run box CMD / this brings up a dos shell in the dos window type IPCONFIG and hit enter.. Note your IP address and your default gateway.. " the default gateway is your device in question. make sure your IP address matches your gateay with the exception of the last 3 octects. so it should read something like this
IP Address 192.168.1.50
Subnet mask 255.255.255.0
Gateway 192.168.1.1
My guess is that your not on the "1" network but the router is handing out a different range of address if that is the case in the dos window type ping (the ip address of your default gateway)
like so ping 192.168.X.X where X = the octet values of the default gateway listed in the dos window
If it replies then your talking just fine you are simply trying to access your router via the wrong IP so take the IP of the gateway listed from the ipconfig command and put that number in your browser.
If this is not the case then we need to go in a different direction with this.
MilToN
CNA,CNE,MCSE,CCNA,Network +
Nov 25, 2007 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
