Question about Mitsubishi SD430U DLP Projector
Hi, I have Projector Mitsubishi SD430U. When I turn on,the projector exclude itself after about 30 seconds. Can I specify the possible causes except the lamp.
SOURCE: how to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
i believe you hit the up and down arrow and the enter button on the projector itself and hold hem in for few seconds and it will display lamp usage.
Posted on Jan 04, 2008
  • 26 Answers
SOURCE: Infocus x1a projector shuts down after 30 seconds - dust problem ??
Most likely, if it is a thermal problem, your main cooling fan has quit or is stopping after a short period. The problem is, I've seen several of these do this, and in every case, it is not the fan that has failed, but the Controller Board. And that is a very expensive part.
Posted on Mar 12, 2008
marsrover
  • 682 Answers
SOURCE: Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Posted on Mar 18, 2008
Marrie
  • 563 Answers
SOURCE: Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
Posted on May 22, 2008
SOURCE: Projector shuts down after only a few minutes.
enter in Factory Menu
1. How to enter factory menu:
I. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve
Posted on Jul 02, 2008
I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this. Can anybody help me to find one
Mitsubishi HC1500 DLP Projector Repair Questions ... - Fixya
www.fixya.com > Forum > Multimedia Projectors > Mitsubishi
Recent Mitsubishi HC1500 DLP Projector questions, problems & answers. ... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
I have a mitsubishi hc1500 projector and it made a popping ...
www.fixya.com/.../t5370392-mitsubishi_hc1500_projector_made_poppi...
I have a mitsubishi hc1500 projector, when i went to turn it off it made a loud ..... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
MITSUBISHI HC1500 DLP 720p Home Theater Projector ...
www.newegg.com/Product/Product.aspx?Item...
Newegg
Rating: 5 - ‎22 reviews - ‎$949.99 - ‎Out of stock
MITSUBISHI HC1500 1280 x 720 DLP 720p Home Theater Projector 1600 ANSI Lumens 2500:1. ... If you are a high-definition video enthusiast who's looking for a more affordable way to bring a front-screen projection to your home theater or family room, the Mitsubishi HC1500 projector is
Dec 27, 2014 | Mitsubishi HC1500 DLP Projector
Mitsubishi HD4000 DLP Projector shuts off intermittenly
Press the reset button for 15 seconds and allow it to reboot. Then turn it off and back on and this will refresh the temperature sensor and not cause it to think it is overheating.
Apr 09, 2012 | Mitsubishi HD4000 Multimedia Projector
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Aug 29, 2009 | Mitsubishi XD480U Multimedia Projector
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Apr 09, 2008 | Optoma EzPro 739 Multimedia Projector
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
Dec 06, 2007 | Hitachi CP-X325 Multimedia Projector
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
Mitsubishi SD430U DLP Projector Logo
96 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
